Kirkn Posted June 28, 2017 Posted June 28, 2017 Hi everyone. Just new to the site. I came into a mountain of hirth parts and have read on here previously that a few people were after them. I have what i need and am willing to sell the rest cheaply if anyone is interested. Just email me at [email protected] Here is the list Hirth Parts rings 014-30/1 x6 Gasket joints 148 B2 x8 " " 207A1 x 11 Recoil Handle x15 Gaskets 1073 3 pack 1072 5 pack 172A2 x 20 Main Bearing x1 Cover plate 195 A1 x 7 Hose Nipple 50k4 x6 Piston pin 014.35/4 x4 Roller Cage 15B31 x20 Roller Ret Spring 75b17 x40 Clamp Ring 75b34 x24 Clamp Piece 75b35 x26 Snap Ring x5 Needle Bearing 046.6 x24 Piston Pin 014.26/4 x5 Crank Key x8 Cover Plate 195 A1 x5 Intake Gasket 207A2 x30 Gasket 055E4 x30 " 212A1 Hirth Engine Parts Cylider & Pistons x2 Heads x2 Pistons 014.35/10 x1 " assorted x4 Belt pulley x1 Cylinder & Bearings x1 Flywheel x1 Green Gaskets x20 Carby 158.2151.65 x1 Vented filler plug x1 Clutch Plate x1 Rev Drum Switch x1 (class 2601) Bosh Starter Fields x4 Starter Gear & Clutch x4 Bushes 4 pack x15 Condensor GB550 x5 Armature x4 Generator coil x4 Starter Carbon Spring x5 Cap 2005821 x2 Starter mot ends x2
