Non locking undercarriage according to TV.
Looks like the pilot did a grand job, be sure to get 'em a drink!
  Quote
Non locking undercarriage according to TV.Looks like the pilot did a grand job, be sure to get 'em a drink!
Yup, and great to see that he'd shut down the left engine too and probably ended up saving that as well. Well done that man.
  • 3 weeks later...
  Quote
Hi Rollerball
You should not shut down a engine if you are going to crash land as if one of the blades are down it may tip your plane.Props bend easy when they are spinning.
Cheers Rory
  Quote
Hi RollerballYou should not shut down a engine if you are going to crash land as if one of the blades are down it may tip your plane.Props bend easy when they are spinning.
Cheers Rory
Somthing tells me that a prop would be no match for a few tonne of a/c and asphalt. Secondly props on a wing wont have enough leverage to tip a plane. Maybe different for a light single
Further to that with the forward momentum and the all up weight of the plane the blade, if one was down, would likely at least bend but probably would shear off at the blade root. I would definitely shut em down if it was a rental and certainly if it was mine.
  • Agree 3
