Deskpilot Posted October 24, 2017 Posted October 24, 2017 Calling all Rotax 503 experts. I'm in the process off rebuilding my engine and, being a very early(si/sc), it has main bearing plugs in the upper crank-case half. These have a step on them as to indicate a fitment orientation. Anyone know how they should be aligned? Also, when sitting the crankshaft in place, the O-rings (64 x 2) get pushed up so as to be too big Any advice? When I stripped the engine, only debris from earlier rings was present. P.S., engine has still to be finally cleaned so I know it not ready for bolt down.
corvairkr Posted October 25, 2017 Posted October 25, 2017 Deskpilot, Is this any help to you ? Rotax, Rotax 503 aircraft engine repair manual. Jason
Deskpilot Posted October 25, 2017 Author Posted October 25, 2017 Many thanks Jason. It seems that my engine is a mixture of old and new. i.e., provision for rubber plugs(early models) and o-rings(later models). The step in the plugs must be due to wear as there's no mention of orientation in the manual. With regard the o-ring fitment, seems I've got the wrong size in a couple of places. I thought they were all the same size. I've been advised that "most people" leave them out and seeing as I have the plugs, albeit a bit worn, I'll rely on them. It would appear that they're there only to prevent the bearings from rotating in the housing rather than providing compression sealing between cylinders or the outside world. 1
The Baron Posted October 28, 2017 Posted October 28, 2017 Hi Deskpilot, Ring Keith Eden on 0419013643 he should be able to advise you.cheers, Steve.
Deskpilot Posted October 28, 2017 Author Posted October 28, 2017 Thanks Steve, will try during next week.
Deskpilot Posted December 18, 2017 Author Posted December 18, 2017 Sing along now..."What a difference a day makes......." de-coking my pistons. 24 hours soaking in WD-40 and a light scrub with a pot scourer. I said LIGHT......OK! According to advice found on the net, there should be markings on the top to indicate which side faces the exhaust port. I can see some id marks but nothing else. How do I determine the correct way to refit them?
facthunter Posted December 18, 2017 Posted December 18, 2017 By where the ring gaps are. Don't have them so as to go near the exhaust port. Nev
Downunder Posted December 18, 2017 Posted December 18, 2017 Tip.... if fitting rubber o-rings or seals, use pbr rubber grease (a tube will last a lifetime) if lubrication is required. Do not use crc, wd-40 or mineral oil/grease. The rubber can swell, become difficult to fit and the life span reduced.
Deskpilot Posted December 19, 2017 Author Posted December 19, 2017 Thanks Nev, thanks advice at the right time. Downunder, your advice has come too late. I've already reassemble the crank case using WD-40. Not going to take it apart again.
Deskpilot Posted March 21, 2018 Author Posted March 21, 2018 Can I swear and swear and swear? No? Damn it. In my post #11, I said I'm not going to take it apart again. Well,whilst re-mounting the engine on it's base plate this morning, I suddenly realized that I'd mounted the cylinders and heads back to front. ie, carburetor on the starboard side, exhaust on on port. How I came to do it I've know idea as I had marked the parts when I took them off. FWIW, it went together no problem.
Deskpilot Posted March 21, 2018 Author Posted March 21, 2018 Please ignore my last post. I'm going mad. After taking a break I went and had another look. It's right after all Thank God. Maybe I got out the wrong side of the bed this morning.
facthunter Posted March 21, 2018 Posted March 21, 2018 I didn't larf , because anyone who hasn't made a mistake hasn't made anything. Hope the pistons are in correctly for the ring pegs. Nev
Deskpilot Posted March 21, 2018 Author Posted March 21, 2018 Thanks guys. My next problem soon raised it's ugly head, refitting the gearbox with the few studs I have left over. Don't think I've lost any of them but there's more holes than studs. I looked up views of an exploded engine and got totally confused as to what type of gearbox I have. I initially thought it was a type B but then changed my mind to a type A with an adapter plate. ????????? Engine as found. I'll play with it again today after I remove the recoil starter assembly. I found the magneto securing nut and washer still on my bench last evening. Ya know, I always thought I was a careful planner and orderly in stripping engines (I've done quite a few early types when home maintenance was possible) but this is my first 2 stroke. Simple....yes, but I'm confused by that simplicity.
Deskpilot Posted March 22, 2018 Author Posted March 22, 2018 MESSED UP!!!, I didn't mess up, I had a slight brain fade. It'll happen to you when you reach my age(76) Not having a go but there's no way I'm pulling it apart again. It's all there somewhere, just got to get it into the right order.
Butch Posted March 22, 2018 Posted March 22, 2018 It'll happen to you when you reach my age(76) Don't worry mate my Grandfather used to say " your only as old as the woman you feel". I suppose aircraft count as a female ! So your still young!
Deskpilot Posted March 22, 2018 Author Posted March 22, 2018 Haha, too true Butch. I was hoping somone would confirm what type of gearbox I have. Please
Methusala Posted March 22, 2018 Posted March 22, 2018 The "A" type and the "B"type boxes are, as far as I know, identical in size. The difference is mainly in the no. of Bellville washers exerting pressure on the clutch. I had the modification done by Floods years ago.
Deskpilot Posted March 24, 2018 Author Posted March 24, 2018 Meth my man, not so sure about your statement. Mainly as there's no clutch involved.
Methusala Posted March 25, 2018 Posted March 25, 2018 When I say "clutch" I am referring to the coupling which consists of 2 mating inclines which is spring loaded by the bellville washers. This is designed as a simple slipping coupling to minimise transmission of power pulses to the propeller which would act as an inertial flywheel. Called a dog clutch I think. (Ahem...) If you can get my drift. Also, the "A" type box had a rough, sand cast finish: the "B" box was smooth. Just found this link to Youtube also.
