Trying to understand a factory installed switch labled "cabin heat" seems to do nothing, although I can see there are wires attached. No apparent heat or voltage drop so I can't imagine an electric radiator.
Nothing in the POH or maintenance manuals. (Flysynthesis)
Can anyone please shed light on this mystery?
  Quote
usually a pipe from around the exhaust to heat air and the cable you pull opens a butterfly to let the heat into the cabin
Yes that is what I have seen in the past but this is simply an electrical switch.
I even wondered if it powered a fan or something - but no evidence of that.
Got me stumped.
Has small electric heater behind panel mounted to fire wall it could be black in couloir about 6"x6"x2" could have fan I think not should be up high Neil
I'll take a look. I would say it's either been removed, disconnected or is faulty as I would expect a measurable voltage drop which you switch something like that on.
Was one fitted on your Storch Neil?
