motzartmerv Posted December 13, 2007 Share Posted December 13, 2007 Hi, anyone know the approach procedures for moree? The ersa says to refer to aip, but i don't have one handy..I'll be approaching from the south and departing to the north... cheers Link to comment Share on other sites More sharing options...
mlpinaus Posted December 13, 2007 Share Posted December 13, 2007 Try http://www.airservices.gov.au/publications/aip.asp . Type I agree and it gets you the latest ERSA., AIPs etc Marcus :) Link to comment Share on other sites More sharing options...
slartibartfast Posted December 13, 2007 Share Posted December 13, 2007 Airservices has the AIP online here. Have a great trip. Ross Link to comment Share on other sites More sharing options...
slartibartfast Posted December 13, 2007 Share Posted December 13, 2007 Doh - beaten by 2 minutes. Link to comment Share on other sites More sharing options...
motzartmerv Posted December 13, 2007 Author Share Posted December 13, 2007 Thanx guys..this forum rocks... cheers Link to comment Share on other sites More sharing options...
Guest J430 Posted December 13, 2007 Share Posted December 13, 2007 Assume you are flying VFR....... It is a CTAF ® so a radio, normal CTAF procedures but I would carefully monitor the BNE CEN well out, listening for any RPT movements, and at about 20NM out check the AWIB, make your runway selection and fly a circuit or straight in following the normal rules. Great aerodrome. If you still need help, PM me. Have been ther many times. J Link to comment Share on other sites More sharing options...
Guest Crezzi Posted December 13, 2007 Share Posted December 13, 2007 It is a CTAF ® J I'm sure when I was last there that it was CTAF rather than CTAF® - has it changed recently ? John Link to comment Share on other sites More sharing options...
Guest RogerRammedJet Posted December 14, 2007 Share Posted December 14, 2007 If your VFR, there are no "approach procedures"! Rog Link to comment Share on other sites More sharing options...
Guest J430 Posted December 15, 2007 Share Posted December 15, 2007 I may be wrong about the CTAF ®.....for me I assume everywhere is, but thats a good point. I know it has RPT and as I would think that at least would have it being a CTAF®. Could be wrong. Either way......no special ops there for VFR's, and have a radio! J Link to comment Share on other sites More sharing options...
Mazda Posted December 16, 2007 Share Posted December 16, 2007 There actually isn't a separate "CTAF®" type of airport really. A CTAF is a CTAF. It isn't like the old CTAF vs MBZ/MTAF rules with different dimensions etc. Having ® shown after the frequency in ERSA just means a radio is mandatory. Procedures are the same. Link to comment Share on other sites More sharing options...
Yenn Posted December 16, 2007 Share Posted December 16, 2007 Basically CTAF® is the old MBZ except the size is smaller. You can fly into a CTAF in an aircraft without radio, but if radio is fitted you must use it. Link to comment Share on other sites More sharing options...
Ross Posted December 16, 2007 Share Posted December 16, 2007 I looked up my current ERSA effective 22nd Nov 2007 with the next issue to be effective on 13th march 2008. According to it Moree is a plain CTAF with an AFRU on 126.7 megacycles. So it may be used by a VFR pilot without a radio but if he has one it must be used. If it were a CTAF® it could not be used by a VFR pilot without a radio. I heard of a pilot test flying an aircraft after a major having a radio failure. So he landed on a farm airstrip (which he knew well) made a phone call to the aero club and asked for his arrival back at his home aerodrome without radio to be broadcast from the club radio at a prearranged time. It was an MBZ at the time. For any additional information check the current NOTAMS for that aerodrome from Air Services. Regards Link to comment Share on other sites More sharing options...
Mazda Posted December 17, 2007 Share Posted December 17, 2007 Yenn, it might be a small point but a CTAF is just a CTAF, not an MBZ! MBZs had different dimensions, so saying they are the same might lead to confusion. Having ® after the frequency only means that you need a radio to operate at that CTAF. Link to comment Share on other sites More sharing options...
Yenn Posted December 17, 2007 Share Posted December 17, 2007 Hey Mazda. Isn't that what I said. At least it is what I meant by using the word basically. Link to comment Share on other sites More sharing options...
Guest Tony Niovanni Posted January 13, 2008 Share Posted January 13, 2008 In this day and age every one should be using a radio at every air port no excuses, as their are many to chose from and not expansive, and helps with the safety aspect Tony Link to comment Share on other sites More sharing options...
Barefootpilot Posted January 13, 2008 Share Posted January 13, 2008 Sorry Tony I don't agree. We've been flying for over 100 years now without radios! The mark one eyeball has always worked well the radio is only a back up. Link to comment Share on other sites More sharing options...
BigPete Posted January 13, 2008 Share Posted January 13, 2008 C'mon Adam - situational awareness, thats what a radio gives you - (a big picture you can visualize but you don't have to "see") someone rolling on 17, someone over flying at 2500, someone 10 miles to the east at 1500, inbound, someone joining crosswind for 35, all this, and a lot more could be happening as you taxi off to the run up point, and, it it is the 21st century. well..... that's my friendly opinion. ;) regards Link to comment Share on other sites More sharing options...
Barefootpilot Posted January 15, 2008 Share Posted January 15, 2008 Yes Peter I do agree a radio does give you great situational awareness if used correctly. I am biased, I fly for a living and get stuck listening to the radio pretty much every time I go flying. This is great for work as its a busy area with a big mix of aircraft. On the other hand when I get out in the Thruster I love the fact that I have the wind in my hair the Rotax screaming away and thats it. Its nice to relax and enjoy the view. In saying that I fly at a resonably quiet airfield and I keep my eyes firmly open! I am in no way saying radios are evil but I don't agree that everyone should have to have one! I believe the CTAF and CTAF® work well keeping the busy airports radio bound but allowing those fuddy duddys like me to still have the freedome to have a little bit of quiet time! Adam. Link to comment Share on other sites More sharing options...
Mazda Posted January 16, 2008 Share Posted January 16, 2008 That's true BigPete, a radio goes give situational awareness. The important thing is not to rely too much on it though as there may still be aircraft in the circuit with no radio, or on the wrong frequency etc. A radio is a good idea but everyone still needs to look out! Link to comment Share on other sites More sharing options...
