Looking good. We have had the same drone issues here in the UK - looking at military bases mainly 😱
"Finished" that sure would-be music to my ears when I can say it with my own mouth. It seems the closer to flight you get the farther away you really are.🤔 Cost of supplies has become a challenge in this neck of the woods along with shipping. Regardless of all the setbacks with a build having fun and enjoying the product is a thing a builder should keep foremost in their mind. 👌Along with safety......................
Edited by Don J
Hi Don,
Its too cold in my workshop to glue at this time of year so I am getting on with the metalwork.
I have got the wing fittings water jet cut. Much better than laser as the laser heat treats the metal as it cuts.
Undercarriage and associated fittings are progressing.
Engine? After much angst I am going for a VW 1776cc with a 110 or scat 25 cam. Single port heads with 1:1:1 rockers. This should give enough power but the torque will be lower in the rev range. The case has been vapour blasted, now to get a line bore.
IMG_2085.thumb.jpeg.3f70b3db74aa99a045492f437280b964.jpegIMG_2086.thumb.jpeg.e5354a4ebf5e5d3660d973b2ba216480.jpeg
You want to make sure that is done very accurately. Are you decking the block or using oversize OD bearings?  Nev
Teggles. I was a bit more curious about how the cable routing is going along with seat type and placement. Are you going steam gauges or do you have more updated goodies for the dash?
The rudder cables were - as you said  straight forward. Elevator I am still working on, but I had a breakthrough when a friend sent me some pictures of the inside of his machine. Some angled pulleys has made for a neat system, so I will try to replicate that. He also had an issue with the aileron cables. As he moved the stick fore and aft the ailerons moved as the cable was tensioned. Both ailerons going up or down together. He has solved that by routing the cable from the bottom of the stick through the torque tube (picture attached).
I am going for steam gauges, simple, reliable.IMG_2090.thumb.jpeg.678bb9933f59a9becd573a39627f7666.jpegIMG_2089.thumb.jpeg.e82c148d4d041d7ca0246dcc8829cdbf.jpegIMG_2088.thumb.jpeg.8451774da62dc25a3cec1b580142c045.jpegIMG_2091.thumb.jpeg.9f48e7087a89a6dde97cc61e2d41d485.jpeg
Edited by Teggles
Very interesting cable arrangement. Aileron cables arranged in torque tube look to be a problem solver. I would only study the over 90-degree return at pully of cable aft of rear spar ensuring no cable can touch under tension. Thumbs up Teggles
Edited by Don J
Merry Christmas to you my friend also and to all. build on and have fun with it.
  • 4 weeks later...
Just collected my legs from a local engineering firm. They have done a great job. Axles and torque links next IMG_2118.thumb.jpeg.3d854d322b1ba3020f93d8b48171eea8.jpegand I will have a pair of undercarriage legs 😁
  • Like 4
  • More 1
Thats great Teggles. Keep at it and it won't be long, and you will be doing taxi runs.
  • 2 months later...
Productive couple of days in the workshop. Undercarriage stop rings, axles and torque link brackets all done. Soon it will be welding time. Just need to make the torque links. The brackets for the legs are with the welder now. After the torque links I need to assemble the centre spar and then I will have an aeroplane on its wheels 😁
  • Like 7
I've got some good  Motorcycle tele forks that would do that job wel, Damped and all. Are you using scissors Links? Nev
  • 2 weeks later...
I may have sourced some links which have been CNC’d from an aluminium block, they look nice - but they haven’t come back to me with the cost 😬
Undercarriage mounting brackets. 14 deg +/- 30 mins! Just need to finish the centre spar. She will soon be on her legs.
  • Like 5
Not by me! There is a company near me which makes replicas of historic cars, fantastic craftsmen and great welders.
