Any gurus out there who have used (or know of an instance where) a Suzuki G10T turboed car engine that's been converted for experimental Cat 19 RAA aircraft use? Apparently the ICP Savannah VG was/is offered with that power-plant option from the factory. Wanting to establish if it could suit a Pietenpol. Any leads would be gratefully received. Tks n rgds.
A number of people who have used them have had no trouble with the engines themselves, but with other things falling off the aircraft due to torsional vibrations that are quite bad with some 3 cylinder engines.
That's all I got.
We know that popular 2-stroke Rotax 503 and 582 are not certified aviation engines but variations of snowmobile engines with all 2-strokers' problems
Who is "we" ?
burn him @mnewbery
SPG-2
This gearbox was designed for
aviation conversion
of engines up to
180 h.p. It has been in production
since 2000. The available reduction
ratios are 2.03, 2.34, 2.5. There is a
German (BMW) rubber damper
between the gear box and the
engine.
The propeller moment of inertia up
to 9,000 kg/cm2. Rotax-style
propeller hub, propeller shaft with a
hole. It is possible to use this
gearbox for both (tractor and
pusher) layouts. A hollow output
shaft allows for variable pitch prop.
.The advantages of this conversion
kit are its big TBO and reliability,
with the possibility of using
heavy propellers. Using this kit, you don't need
to change belts and pay
for them. You don't need
to modify the engine block so the
mechanical part of conversion is very simple - just bolting the
gearbox up. You will keep a stock water outlet wit
h thermostat. I heard a
lot about overheating
problem from people using conversions with modifi
ed water cooling system but have never had it
even with my small radiator closed
by BRS system. It is also its hi
gh efficiency. For example, I got
375lbs of static thrust from
my stock unmodified engine with
a 2.5 RR gearbox and low noise 69"
3-blade carbon propeller.
Now we provide not only
conversion kits but also
ready-to-install power
plants based on low-mileage stock or completely
remanufactured and modified GEO-Suzuki
engines. We also sell gearbox conversion kits
for the Subaru EA-71 EA-82
EJ-18 EJ-20 EJ-22.
CONTACT DETAILS
Suzisport Springwood
3339 Pacific Highway Springwood
Ph: 07 3808 7637 Fa
x : 07 3808 7519
E
[email protected]
Wow that was too easy. Someone by the name of "ignored member" keeps coming up in the responses just after I write a reply in a lot of these threads. No idea who it is or what they are saying. Probably drivel.
060_popcorn.gif.cda9a479d23ee038be1a27e83eb99342.gif059_whistling.gif.a3aa33bf4e30705b1ad8038eaab5a8f6.gif027_buddies.gif.22de48aac5a25c8f7b0f586db41ef93a.gif
Any who, I am trying to track down a NSW pilot who was using a G13B or something like it in a Moyes Dragonfly to tow hang gliders. If I can find out anything I will post pictures
Ignored member could be any of us. I always feel ignored when I post. :rotary::rotary:
that's terrible Steve.
