Admin Posted October 20, 2018 Posted October 20, 2018 As you will now see the side column menu system has been implemented based on the recent poll showing an overwhelming vote to reintroduce this style of menu. By default it is on the Right Side of the screen however to have it displayed on the Left Side: 1. Click your icon at the top of the menu and select Preferences 2. In your preferences simply click Left on the Menu Position option It may look a bit bare at the moment but soon it will look like this: 1
kgwilson Posted October 20, 2018 Posted October 20, 2018 Great. It is back to front in WUA but ticking Right puts it on the left. 1
Admin Posted October 20, 2018 Author Posted October 20, 2018 Great. It is back to front in WUA but ticking Right puts it on the left. Fixed now on Whats Up Australia...thanks for letting me know
red750 Posted October 20, 2018 Posted October 20, 2018 When I change from What's New to a thread, or vise versa, the screen appears as shown below, with the menu overlapping the main page, when set to Left margin. It may be for a fraction of a second, up to a second and a half. It does not occur when right margin is selected. It's like the main screen is loaded for a right margin, then the margin loads on the left and bumps it across. I thought it may have been the screen resolution was set too high, but reducing it to 67% did not correct the problem. It happens on both sites. It also happens if I am on New Posts, and click New Posts to refresh.
old man emu Posted October 20, 2018 Posted October 20, 2018 I'm glad it was so easy to get the Nav bar over to the left. Don't go into Labor about it. Just put the cross in the correct box
Birdseye Posted October 20, 2018 Posted October 20, 2018 The LHS takes up a lot of real estate. Maybe dump that now? 1
red750 Posted October 20, 2018 Posted October 20, 2018 Maybe a poll to see how many want to keep the Members details panel.
Bernie Posted October 20, 2018 Posted October 20, 2018 It doesn't need to be as big as it is , it takes up too much room on the side panel . Bernie . 1
kgwilson Posted October 20, 2018 Posted October 20, 2018 It doesn't matter when you have a large 16:9 screen. It also disappears once you have selected the thread to read.
Admin Posted October 20, 2018 Author Posted October 20, 2018 The LHS takes up a lot of real estate. Maybe dump that now? Dumping the side column in the Whats New section that holds the What's New menu and member birthdays etc would mean the removal of the What's New menu box leaving only the sub menu across the top. The What's New page seems to be one of the main landing pages for many users so I was planning on having a Clear Prop specials box along with upcoming aviation events (the member boxes currently there are just space filler for the moment) in that side space as well so by removing that space will also remove that opportunity. So are you sure you want this done? Do I run a poll? Or ....
Admin Posted October 21, 2018 Author Posted October 21, 2018 When I change from What's New to a thread, or vise versa, the screen appears as shown below, with the menu overlapping the main page, when set to Left margin. It may be for a fraction of a second, up to a second and a half. It does not occur when right margin is selected. It's like the main screen is loaded for a right margin, then the margin loads on the left and bumps it across. I thought it may have been the screen resolution was set too high, but reducing it to 67% did not correct the problem. It happens on both sites. It also happens if I am on New Posts, and click New Posts to refresh. [ATTACH=full]62162[/ATTACH] @red750 I will see what I can do about the speed issue however a fix for that can not be implemented immediately as there are some other things that I am doing that the flow on from them will fix the issue
red750 Posted October 21, 2018 Posted October 21, 2018 No hurry, Ian. Not a major problem. Minor irritation sometimes, that's all.
kgwilson Posted October 21, 2018 Posted October 21, 2018 It is my home page so I like it and as I said I have a 16:9, 24 inch screen so space is not a problem
kgwilson Posted October 22, 2018 Posted October 22, 2018 When hovering over a members avatar, the detail is partly obscured by the new side menu, presumably because the side menu is specified to be always on top. All detail is shown when clicked as it opens a separate page.
