 AIRCRAFT QUESTION
As clever as you might be, I’ll be surprised if you actually get this right but you will get it once you see the  answer.
raw?appid=YahooMailNeo&ymreqid=bf5e5169-2c49-741a-0154-3e0004010000&token=zitEzqOML3j84e6ealFTT5U7-km5qEQF52lp7AcCuBZSA0GMCw1cCK9Zlh458qMU7uGuChdVzBjj_kVg55qOyFdBSxMQmCRelNCBAXDzx2JEAPFEdh87XPVZpLB7W2JW
They say it is common sense but here is a Clue: Just remember that a helicopter's blade (in cross-section) is shaped like an airplane's wing, and both catch air giving  lift.
Now answer the question…. This should be an easy quiz for those who have even a modicum of knowledge about aircraft.  However, the answer may surprise you.
The Question:
  "What is the primary advantage of rotary winged aircraft
over fixed-winged aircraft?"
I got it wrong, too!
Bugger it!
Well, yes, but I wouldn't mind standing behind her if she were wearing the same output standing close behind a prop-driven plane with the engine running...
