Guest jimbo_xyz Posted February 8, 2008 Posted February 8, 2008 I'm sure most of you have seen this one before, but it always makes me laugh. To those who haven't seen this before, enjoy! After every flight, UPS pilots fill out a form, called a 'gripe sheet,' which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident. P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. P: Something loose in cockpit S: Something tightened in cockpit P: Dead bugs on windshield. S: Live bugs on back-order. P: Auto pilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. P: Evidence of leak on right main landing gear. S: Evidence removed. P: DME volume unbelievably loud. S: DME volume set to more believable level. P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. P: Suspected crack in windshield. S: Suspect you're right. P: Number 3 engine missing. S: Engine found on right wing after brief search. P: Aircraft handles funny. (I love this one!) S: Aircraft warned to: Straighten up, fly right, and be serious. P: Target radar hums. S: Reprogrammed target radar with lyrics. P: Mouse in cockpit. S: Cat installed. And the best one for last................ P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget.
Guest Redair Posted February 9, 2008 Posted February 9, 2008 Very funny, but I do doubt whether these are genuine, as I have seen the same list with claims to have been from Qantas, BA, ParcelForce and another cargo company (the name of which escapes me at the moment). Me thinks this could be one of those urban myths!! And for those that don't know what a Myth is.... it's a female Moth:laugh:... and that's got to make you wonder what those MythBusters are really up to!!!!! Redair.
Mathew Ker Posted February 10, 2008 Posted February 10, 2008 Now I',m really confused. I thought a myth was a dead moth! ;)
Guest Redair Posted February 11, 2008 Posted February 11, 2008 No, no, no.... that's a "Mort" Redair.
1946 Posted February 12, 2008 Posted February 12, 2008 So, a mortician is a dead moth who had a bad case of the sneezes!
Guest Redair Posted February 12, 2008 Posted February 12, 2008 the force of which can be measured by a Mortgage! Redair.
