Uncle Chop Chop Posted December 18, 2008 Posted December 18, 2008 I was browsing throught Jet Photos and found 2 pictures. The 1st Picture is of the 2nd Qantas A380 on finals for Sydney International Airport. The main landing gear is angled forwards. The 2nd picture is of a Qantas Boeing 747-400 . The landing gear is angles backwards. Now I know they are completly different Aircraft with different manufacturers and designs but why would the A380's landing gear be angled forward? On a hard landing wouldn't there be a risk of the landing gear tipping forward and actually breaking? Qantas A380 http://www.jetphotos.net/viewqueued_b.php?id=2262086 Qantas Boeing 747-400 http://www.jetphotos.net/viewphoto.php?id=6438084&nseq=4
Guest Glenn Posted December 18, 2008 Posted December 18, 2008 Both aircraft look to be at different angles. A380 appears to me is landing and the 747 is taking off. Could just be the different angle of attack having different effects to the gear
PlaneInsane Posted December 19, 2008 Posted December 19, 2008 It seems to be both are landing. The 747's angle of attack for take-off is greater than what it is in that photo right? Also the degree of flap. (i may be wrong) Uncle Chop Chop, maybe it has something to do with weights?
sixtiesrelic Posted December 20, 2008 Posted December 20, 2008 The Bogeys pivot. Tires roll, so when the wheel touches down they spin on their axles and as the aircraft settles down onto the runway, the bogeys pivot happily on their "axle". There is no real great drag on the leg. To HIT the ground hard enough for the A380 U/C to tip would have the floor of the second storey of the cabin getting worn out along the runway in a spectacular shower of sparkes. All large aircraft have so much momentum that they have to be flanded very gently and if they touch down while sinking surprisingly gently for what they can safely sink at in flight, you will have the undercarriage fail, so it doesn't matter which way they droop.
Guest David C Posted December 20, 2008 Posted December 20, 2008 Different aircraft types have different angles to their main landing bogies .... Why ??? ... I've no idea .. Take for example the 767 . The main bogies are angled forward , but the 747 is angled backwards . Incidentally , talking to 767 jockies , they all say that the 767 is easy to land but difficult to land well , and they all say it's due to the angle of the main wheel bogie .. Dave C
Uncle Chop Chop Posted December 21, 2008 Author Posted December 21, 2008 Hey guys. First of all thanks for the replies. Sixties, great post and good to see you back.
