Guest Escadrille Posted February 14, 2008 Posted February 14, 2008 Hi all, Can anyone tell me where I can buy a suitable tacho to suit a VW (HAPI) 1835 aero engine. I don't want a huge great Beetle instrument. Surely VDO or Smiths make one suitable that I could buy from Autopro or Repco? Anyone know for sure of type nos or of an outlet in Australia? Thanks, Andy
Guest spacewalker Posted December 23, 2009 Posted December 23, 2009 Andy, It depends on what type of ignition system you are using. Some take the signal from the negative side of the ignition coil, some wrap around the HT lead and others need a pickup placed on the flywheel or alternator. I have just been through this and my advice was to use a Tiny Tach. However, Wadair advised me that they have some problems when fitted to 4-strokes, so still looking... Martin
Methusala Posted December 24, 2009 Posted December 24, 2009 VW Tacho Dear Andy, Used a Tiny Tach on my VW for years. Just need unshielded leads and a few raps of the sensor wire around will do it. When the battery finally gives up the ghost you can carefully dismantle the case and install a watch battery and go again. No problems. Regards, Don.
Smokey Posted December 25, 2009 Posted December 25, 2009 Hi Andy I've had occassion to talk to VDO several times over the years, always most helpfull. I'd have a chat with them, you'll probably find they've got a choice to suit. http://www.au.vdo.com/generator/www/au/en/vdo/main/home/home_en.html Mark
Methusala Posted December 25, 2009 Posted December 25, 2009 Yes but... the Tiny Tach is digital and accurate, easy to read, does work well on 4 strokes and incorporates an hour meter all for around $100. Hard to beat! Don
