Guest Darren Masters Posted February 17, 2009 Posted February 17, 2009 You sure did buster :biggrin: What advise worked?
Robbo Posted February 17, 2009 Author Posted February 17, 2009 moved the scanner away from the battery charger !
Robbo Posted February 18, 2009 Author Posted February 18, 2009 getting stuff on acars using the program now..
Guest Darren Masters Posted February 18, 2009 Posted February 18, 2009 Yes you see some interesting stuff on there. Once you use ACARSD though for ACARS you will never look back. It decodes with minimal errors.
Robbo Posted February 18, 2009 Author Posted February 18, 2009 some weird stuff coming up on this !! F03A 7:58:02 PM 18/02/20094 2 Msg Label: H1...MESSAGE TO/FROM TERMINAL Aircraft Reg: .VX-VXP Flight No: QF0$&5 Message: #M1BPRG/ S39A 7:57:50 PM 18/02/20092 2 Msg Label: Q0...LINK TEST Aircraft Reg: .VX-VXJ Flight No: QF0038 Airline: QANTAS AIRWAYS DOWNLINK NAK S55A 7:41:22 PM 18/02/20091 M Msg Label: 5V Aircraft Reg: .VH-VXN Country: AUSTRALIA Flight No: QF0656 Using Ground Stat ion: Manchester
Guest Darren Masters Posted February 18, 2009 Posted February 18, 2009 Yeah it does that sometimes. It is not decoding the messages correctly. I'll tell you again, throw it in the rubbish and get ACARSD. You won't have that problem with ACARSD.
Robbo Posted February 18, 2009 Author Posted February 18, 2009 cant install it, system is locked down. Must be able to run without install. Plus ACARSD streams it for public use i dont want that.
nzom_pilot Posted February 18, 2009 Posted February 18, 2009 Pity your system is locked down and you cant install ACARSD cause as Daz says its the best :biggrin: I use it over here - it doesn't stream it to the public if you don't select those options, I've used ACARSD for nearly 2 years and never once has my stuff gone past my computer
