Here's a couple of photos of re-cycled Mig-15 Klimov VK-1 turbojet engines used as airstrip snow blowers and aircraft de-icer's in Russian airports.
These were basically a clone of the Rolls Royce Nene.
[ATTACH=full]1273[/ATTACH]
This high mounted version with the extended exhaust is used for de-icing aircraft.
[ATTACH=full]1274[/ATTACH]
This one's for clearing railway tracks & still has the cockpit and part of the fuselage.
[ATTACH=full]1275[/ATTACH]
Water injected jets mounted on a tank and used to blow out oil well fires in the First Gulf War.
Don't know what engines they are.
https://www.youtube.com/watch?v=uyGDxglTVgA
Cheers, Willie.
[ATTACH]18231[/ATTACH]
Found this link to a lengthy blow by blow description of the oil field fire suppression rig in the above video. Interesting reading if you like that sort of thing.
http://www.caranddriver.com/features/stilling-the-fires-of-war
Apparently it was based on a WW2 T34 Russian tank, and was designed by an Arab owned, Hungarian drilling company, using a Russian idea. The engines are Tumansky R-25's, which were used in the Mig-21bis. The T34 was retired after the Gulf fires and the rig was then placed on a T55 tank, as in the photo in the linked article.
It's a bit of a beast.
Cheers, Willie.
  Quote
By the look of the tank on that high mounted one there'd only be enough fuel in the round tank for mebe 1.5 hours running :eek:
At a rough guess at the size of the tank and fuel consumption, I recon you'd be fairly close to the money there, Student Pilot.
Cheers, Willie.
