Vision325 Posted August 2, 2006 Posted August 2, 2006 Hi All, Thought I would post a few pics of a my project that I have taken over. This aircraft is called a Vision, it is designed by Steve Ramm of American Affordable Aircraft. It is a mouldless 2 place fibre glass foam sandwich design. The fibre glass surfaces can be made using a framing teqnique or by vacumm bagging flat panels and just bending them into shape like constructing a card board box (foldaplane method). I will use both but the inverted fuse in the picture is produced by bulding a frame and bending foam into place then glassing outside. Then next pic is the post cure oven I built to stiffen and bring the resin to its full strength. 70 degs celcius for 4 hours. This is a picture of the fusalage flipped and being prepared for glassing of inside fusalage. 3000 to 5000 hours later it should look like this. To be continued!!!
Ed Herring Posted August 2, 2006 Posted August 2, 2006 A great project Stephen....keep the photo's coming mate! Regards Ed
zodiac3813 Posted May 21, 2007 Posted May 21, 2007 Hi, What a great project! Did you buy the plans from the U.S.? Looking at the fuselage photo, what did you build the frame (that the foam is bent over) out of? What kind of foam? I am looking for a new project to start after I sell my (plans-built) Zodiac 601. Cheers for now.
Robert Posted May 22, 2007 Posted May 22, 2007 Vision plans Hi If anyone interested I have a set of unused vision plans for sale
TechMan Posted May 25, 2007 Posted May 25, 2007 There is also a Vision being built here in Canberra. Can put anyone in touch if required. Chris
