fly_tornado Posted June 30, 2019 Posted June 30, 2019 prototype finished, about to start test flying 6
old man emu Posted July 1, 2019 Posted July 1, 2019 I can see a fingerprint on the polished aluminium! Beautiful work!
facthunter Posted July 1, 2019 Posted July 1, 2019 The Wings I would think. it's a pretty close copy of a Ryan the only giveaway is the thin prop no exhaust stubs and there is a pylon on the fuselage in front of the forward cockpit for the landing wires and to make egress easier when it's upside down on the ground. Good looking job. Nev
fly_tornado Posted July 1, 2019 Author Posted July 1, 2019 Quote FT it's beautiful, but which part is wood? have a look Timber Tiger Aircraft-home of the Sport Pilot friendly Ryan ST replica 1
Davidnane Posted October 22, 2019 Posted October 22, 2019 i want to know that for newly construction of HOMEBUILT Aircraft, how i can test that the structure is okay and i can fly in air without any accident?
facthunter Posted October 22, 2019 Posted October 22, 2019 The DESIGN should have covered that aspect provided your materials and construction methods are Aircraft standard or to the design specs. If you are using wood it's more difficult . You need to be quite knowledgeable on wood selection, grading and application . Test pieces are subject to measured loads, to make sure they exceed the required material specs. Glued joints, specifically should be thoroughly tested. There's a lot of this info on the American scene where homebuilts were well served with useful information. Tony Bingelis sp? has authored a series of books an all aspects of homebuilt construction. Recommended. Nev 1
