Vev Posted June 11, 2010 Posted June 11, 2010 Bushpilot quote - "The J120, regardless of category, is 430 kg - same as the old ST models." Chris, Am I not getting a point you are making? Are you sure about the 120 MTOW ... I thought it was 500kgs? Cheers Jack
bushpilot Posted June 11, 2010 Posted June 11, 2010 Bushpilot quote - "The J120, regardless of category, is 430 kg - same as the old ST models."Chris, Am I not getting a point you are making? Are you sure about the 120 MTOW ... I thought it was 500kgs? Cheers Jack It could well be; my info is based on what Ive been told, not what I know.. But in all cases check the flight manual, as same model aircraft can vary in certification; especially if buying a used aircraft.
