zodiacpilot Posted July 6, 2019 Posted July 6, 2019 Hi all, looking to 'beg, borrow, steal, or buy' a pusher to suit o200 continental ( 58x67) or close. Cheers.
spacesailor Posted July 7, 2019 Posted July 7, 2019 Should I get the axe out & make one. LoL spacesailor
facthunter Posted July 7, 2019 Posted July 7, 2019 Why is there any difference? Tractor or pusher. as long as the holes match the bosses in the drive flange. Nev
Thruster88 Posted July 7, 2019 Posted July 7, 2019 'facthunter said: Why is there any difference? Tractor or pusher. as long as the holes match the bosses in the drive flange. Nev No difference, if you don't mind flying backwards ? 1
facthunter Posted July 7, 2019 Posted July 7, 2019 Yes you are correct I only considered the section of the prop blade. and the engine's thrust bearing suitability. Nev
spacesailor Posted July 9, 2019 Posted July 9, 2019 You could put the prop on backwards, BUT the trailing edge becomes the Leading edge so is inefficient. spacesailor
