JG3 Posted October 31, 2019 Posted October 31, 2019 'facthunter said: The high nose position is not to be considered weird. It's what you must do to reach the limits of the wing. . Nev Exactly correct. Increasing AofA means increasing lift coefficient. It's the ability of the Savannah wing to attain this high AofA without suddenly letting go that makes it such a dependable STOL aircraft. 2 1
Yenn Posted November 1, 2019 Posted November 1, 2019 Why would you take off the slats and put on VGs, then take off heavily loaded and in less than ideal conditions. I would expect to do that work and then test fly the plane to get new figures for stall etc, plus get the feel of the plane.
shafs64 Posted November 1, 2019 Author Posted November 1, 2019 'Yenn said: Why would you take off the slats and put on VGs, then take off heavily loaded and in less than ideal conditions. I would expect to do that work and then test fly the plane to get new figures for stall etc, plus get the feel of the plane. Yes i was thinking the same .
Thruster88 Posted November 1, 2019 Posted November 1, 2019 'Yenn said: Why would you take off the slats and put on VGs, then take off heavily loaded and in less than ideal conditions. I would expect to do that work and then test fly the plane to get new figures for stall etc, plus get the feel of the plane. I was wondering why an over 80 year old would want their plane to go faster. 1
turboplanner Posted November 1, 2019 Posted November 1, 2019 'Thruster88 said: I was wondering why an over 80 year old would want their plane to go faster. At the time, the Savannah with the slats had a very slow cruise speed; I seem to remember 67 kts, but that may not be correct. When you get slow speeds like that and a 30 kt wind on the nose, you are down to a TAS of 37 kts so you sit there burning nearly double your fuel per nautical mile. On cross country flights this takes the shine off the reason you bought the STOL for. The VGs made a huge difference for cross country flying. 1
rankamateur Posted December 29, 2019 Posted December 29, 2019 'Thruster88 said: I was wondering why an over 80 year old would want their plane to go faster. When you are eighty and running out of years, don't you do everything faster if it doesn't hurt too much. It is like when checkout operator at the supermarket stops serving to serve on the nearby smokes counter I never get offended. The customers at the smokes counter have less time left so they don't have time to wait! 1 2
facthunter Posted December 29, 2019 Posted December 29, 2019 I wouldn't advise 80 year olds to build their own plane from scratch. (unless they are supreme optimists) .You don't have the time for that so get out and FLY if that's what you really want. IF you are over 50 even get on with it and don't procrastinate. It's always LATER than you think. and planes take longer to build than you fooled yourself into believing. a while ago. Nev
Yenn Posted December 29, 2019 Posted December 29, 2019 I built 2 since I was 50, but I don’t think I will start another. It would possibly get finished, but test flying could be unwise. I am sorely tempted to do a major overhaul, new skin and panel, but it would be un recoverable money.
Old Koreelah Posted December 29, 2019 Posted December 29, 2019 'turboplanner said: At the time, the Savannah with the slats had a very slow cruise speed... The VGs made a huge difference for cross country flying. Coming home from Temora one year I was surprised to be overtaken by a Sav; he was cruising at around 90kt, so presumably had VGs.
Kyle Communications Posted December 29, 2019 Posted December 29, 2019 90kts is not cruising in a savannah...its pushing it..and the airframe lets you know it too..it changes its sound
skippydiesel Posted December 29, 2019 Posted December 29, 2019 'Kyle Communications said: 90kts is not cruising in a savannah...its pushing it..and the airframe lets you know it too..it changes its sound Gee! I hope its other features make up for its short legs. How much fuel do you carry ?
skippydiesel Posted December 29, 2019 Posted December 29, 2019 'Kyle Communications said: 4 tanks each 36 litres Woweeeee! I only cary 87 L - good for about 6 hrs 40 mins, to dry tanks, at 100 knots. Can do a little better with one up - way way past bladder capacity.
watto Posted December 30, 2019 Posted December 30, 2019 Stol and super stol wing's can develop flutter in over speed and fold, its not designed for horizontal speed only vertical lift.
eightyknots Posted May 15, 2020 Posted May 15, 2020 facthunter said: I wouldn't advise 80 year olds to build their own plane from scratch. (unless they are supreme optimists) .You don't have the time for that so get out and FLY if that's what you really want. IF you are over 50 even get on with it and don't procrastinate. It's always LATER than you think. and planes take longer to build than you fooled yourself into believing. a while ago. Nev I am over 50 and building a Savannah now. Even though there is enjoyment in the building process itself, my principal aim is to fly. ☆ anyway... ...back to building!
eightyknots Posted May 15, 2020 Posted May 15, 2020 Kyle Communications said: 90kts is not cruising in a savannah ...its pushing it ...and the airframe lets you know it too ...it changes its sound. Do you suggest eighty knots is the ideal cruising speed?
Bruce Tuncks Posted May 15, 2020 Posted May 15, 2020 JG3 said: It's a modified NACA 65018. Bottom surface flat instead of slightly under cambered. Martin Symons ( model aerodynamics author) would say that you have used the word "undercambered" wrongly. But its the way I have always thought and so I am guilty too. You actually mean a concave under-surface. "Camber" is the curvature of the mean line between upper and lower airfoil surfaces, so an undercambered wing has not enough curvature of this line.
