Bruce Tuncks Posted December 23, 2019 Posted December 23, 2019 There was once an article in the old magazine by a guy who had a drum on a sack truck with an air pump to pressurize the drum so that fuel would be forced into the upper wing tanks. Well in the next issue, he was pilloried for suggesting something so dangerous. I thought at the time that his only real problem was that air contains 20% oxygen, and that if he were to substitute CO2 or nitrogen, the method would be safe. You could do this with a cylinder of the gas, and when you open a valve, the drum is pressurized. And I think that bottled gas as we use for caravans would be safe too, since it does not contain an oxidizing agent. This last idea is counter-intuitive I know.
skippydiesel Posted December 23, 2019 Posted December 23, 2019 The problem with pressurising a can (Tanami Pump) that is not designed to do so is the potential to have a rupture. Not much of an issue if its kero or diesel but petrol ???
Bruce Tuncks Posted December 23, 2019 Posted December 23, 2019 It's not much pressure needed Skippy. It only has to be about 2 metres of head to pump into a plane. I would bet that this would not worry a 44 gallon drum. Those drums would have to withstand the vapor pressure from petrol inside and cooking in the sun, and this would be more pressure than 2 m of head I reckon. I didn't know they are called Tanami pumps... why is this? Were they popular among the aborigines?
Kyle Communications Posted December 23, 2019 Posted December 23, 2019 Tanami pump is supposed to only be around 2 psi...works fine on larger drums
skippydiesel Posted December 23, 2019 Posted December 23, 2019 It's not much pressure needed Skippy. It only has to be about 2 metres of head to pump into a plane. I would bet that this would not worry a 44 gallon drum. Those drums would have to withstand the vapor pressure from petrol inside and cooking in the sun, and this would be more pressure than 2 m of head I reckon. I didn't know they are called Tanami pumps... why is this? Were they popular among the aborigines? I suggest you Google it for a full explanation.
pmccarthy Posted December 23, 2019 Posted December 23, 2019 Short answer- its a brand name, used by the 4WD fraternity.
skippydiesel Posted December 23, 2019 Posted December 23, 2019 Short answer- its a brand name, used by the 4WD fraternity. Come come there is a little more to it than that - design, fitting, options etc - find it all on line.
petercoota Posted December 26, 2019 Author Posted December 26, 2019 Thanks to all for such a useful discussion, lots of ideas, many new to me. From all these inputs I’ve decided what I’ll do & ordered the bits & pieces. When its all delivered & assembled into a working system I’ll post a video & links. Given the holiday period & delivery delays, it’ll probably be a couple of weeks. Then I’ll welcome comment on what I haven’t thought of, or fundamental flaws in my thought processes. Thanks again to all, Peter 2
skippydiesel Posted December 26, 2019 Posted December 26, 2019 All the best for the New Year Peter - I am sure we all look forward to your observations/comments on the equipment you have selected
petercoota Posted December 31, 2019 Author Posted December 31, 2019 Thanks Skippy, Progress has been sidelined by events in Mallacoota these last few days. Might be a few weeks before I can progress this project...Hope you have a good New Year, Peter
