Thruster88 Posted December 28, 2019 Posted December 28, 2019 While most recreational aircraft do not have impulse couplings on the magnetoes this is a good reminder to always treat the prop as live. Good story as to how it actually happened.
Geoff_H Posted December 28, 2019 Posted December 28, 2019 When I was learning to fly around 1980 I was taught how to swing a prop. Safety and getting out of its way were important. Prop swinging does not seem to be taught these days. I have needed to start my engine several times, the guys doing it for me were much younger than me. I had to teach them. It took 5 minutes.
skippydiesel Posted December 28, 2019 Posted December 28, 2019 Ancient principal ; The older wiser get the younger bullet proof to do the job for them
derekliston Posted December 29, 2019 Posted December 29, 2019 Absolutely gives me the chills when I see people leaning on the propellor for a photograph, particularly when it is a hot engine and the pilot has just doe his first solo or just gained his licence or whatever! 1
turboplanner Posted December 29, 2019 Posted December 29, 2019 Some links which show how easy it is: https://www.faa.gov/data_research/research/med_humanfacs/oamtechreports/1990s/media/AM93-02.pdf https://www.telegraph.co.uk/news/aviation/9627585/Pilot-killed-walking-into-propeller-blades.html
Downunder Posted December 30, 2019 Posted December 30, 2019 The thumbnail from the second vid was enough for me...... couldn't bring myself to watch the vid to be honest....
turboplanner Posted December 30, 2019 Posted December 30, 2019 The thumbnail from the second vid was enough for me...... couldn't bring myself to watch the vid to be honest.... Know how you feel, but that was probably enough, however there was no carnage shown. The Pilot flies a Lear 45 professionally and owns a C177. Had a problem starting, set Mags off, throttle to idle..........but left the mixture rich. On the second pull-through the prop went off and got him under the arm several times. He stuffed a bunch of paper towels unde his arm because he had a pickup to do in the Lear, but changed his mind and got medical attention. He now does a Mag grounding check every time before shutdown.
