Paul davenport Posted May 14, 2021 Posted May 14, 2021 I am looking for a fuel flow meter , don’t need fuel quantity left in tank or any other info JUST flow small enough to fit in a busy dash and at a reasonable price . What’s out there
skippydiesel Posted May 15, 2021 Posted May 15, 2021 Hi Paul - what information are you hoping to get from this fuel flow meter? If you go back, this section, to about the 10 March, you will find a fair bit of information about Fuel Computers - which also give flow.
Paul davenport Posted May 15, 2021 Author Posted May 15, 2021 Just flow rate in litres per hour Don’t need to know fuel left or total fuel used etc. just LPH.
Paul davenport Posted May 15, 2021 Author Posted May 15, 2021 Stand alone gauge not part of glass panel
skippydiesel Posted May 15, 2021 Posted May 15, 2021 Paul - I am guessing that it may be hard to find a gauge/sender that just does L/hr. I think you might have to compromise & go with a fuel computer, that will certainly give you L/hr but also, fuel used/fuel remaining and quite probably accumulated fuel used since last zeroed. 1
cscotthendry Posted May 15, 2021 Posted May 15, 2021 (edited) Have a look at the Flight Data FC-10. It's about the cheapest one available. What Skippy said is the case. It costs very little extra for a manufacturer to put those extra features in the software. The expensive part is the sensor. Edited May 15, 2021 by cscotthendry
Yenn Posted May 16, 2021 Posted May 16, 2021 I fitted a Red Cube to my RV4. Got it from Steinair in USA. Worked well with the MGL instrument which was in place.
Paul davenport Posted May 16, 2021 Author Posted May 16, 2021 Thank you all just the info . Steam gauges fitted so it’s a stand alone gauge I will investigate FC10
Blueadventures Posted May 16, 2021 Posted May 16, 2021 49 minutes ago, Paul davenport said: Thank you all just the info . Steam gauges fitted so it’s a stand alone gauge I will investigate FC10 I have a friend that has a FC10 and red cube fitted this annual; we were planning to run engine today but have put it off until Thursday or Friday afternoon. Will let you know how it goes. I have seen cheap about $60 ones on ebay that may give an indication of flow; I have no idea of quality. Cheers
cherk Posted May 17, 2021 Posted May 17, 2021 On 15/05/2021 at 7:11 PM, Paul davenport said: Stand alone gauge not part of glass panel if its for a 19 reg A'ft https://www.futurlec.com/sensor/gasflowmeter.shtml
skippydiesel Posted May 17, 2021 Posted May 17, 2021 5 minutes ago, cherk said: if its for a 19 reg A'ft https://www.futurlec.com/sensor/gasflowmeter.shtml Wow! that's a good price. I am not so keen on the spigot size (may require some additional adapters = potential failure points) and the use of a separate energy supply has both + & - features.
Blueadventures Posted May 17, 2021 Posted May 17, 2021 44 minutes ago, cherk said: if its for a 19 reg A'ft https://www.futurlec.com/sensor/gasflowmeter.shtml Similar to the one I was mentioning above.
