Hi All, I trust I am able to post an item available.
I have an MTV-7-F/LD 165-03 Composite 3-Blade Pusher Prop available. It is an electric variable pitch constant speed 3-blade pusher propeller, with infinitely variable pitch range from take-off to feathering position via automatic or manual electronic control. The diameter is 165cm, 69”, the pitch is variable from 12 degrees to 24 degrees. It was mounted on a pusher aircraft with Lycoming O-235 engine, used around 500hrs. The prop comes complete as removed, with the spinner, slipring for 235 or other similar size Lycoming hubs, brush assembly, bolts, and a 12V version plus a 24V version P-120U manual/automatic pitch controller. It has all to get it running. Max power 160HP at 2800RPM. It has stainless steel leading edges. The tips are fine, the paint is chipped off, absolutely no dings on the blade’s surfaces, LE or spinner. The LE tape has perished, it will have to be replaced should you want protective tape on it. I’m not going to do a thing to this prop to dolly it up, best it is taken in its current condition. The MT specs are http://www.mt-propeller.com/pdf/datsheet/mtv-7.pdf, installation instructions http://www.mt-propeller.com/pdf/manuals/e-118.pdf. It is a certified prop, I have the original invoice, shipping box, ARC, logbook, manuals, and all the green tags for the components when they were removed from the engine. Of course, it is now out of date, should you want to re-certify it for use on a certificated aircraft. For your experimental, it’s ready to go on.
I am open to offers, I'm in Hervey Bay, QLD.
Posted (edited)
SkeeterJr, there's a classifieds section of the forum that your sale item should be lodged in - not under the "General Discussion" forum. Look on the menu on the LHS of the forum, you'll see the heading "Classifieds".
Hold your mouse over the heading and you get 5 menu options, "Classifieds" at the top. Move your cursor onto the "Classifieds" sub-menu and click on it, and when the Classifieds page opens, you'll find, "Submit an Advert" at the top RHS of the Classifieds page.
Edited by onetrack
Posted (edited)
All Good, was hoping to be able to post in an Ozzie classifieds thread, not open to the world. thanks.
Edited by SkeeterJr
