facthunter Posted December 13, 2021 Posted December 13, 2021 I said you were lucky to have the fluid you have got as you will have no trouble whatever with corrosion. If you topped up in an emergency with light engine oil it wouldn't matter either. You asked that question later. Look if you think what I say is all BS that's easily fixed. I won't be responding to your requests for an opinion again. This has happened before... Nev
skippydiesel Posted December 13, 2021 Author Posted December 13, 2021 3 hours ago, facthunter said: I said you were lucky to have the fluid you have got as you will have no trouble whatever with corrosion. If you topped up in an emergency with light engine oil it wouldn't matter either. You asked that question later. Look if you think what I say is all BS that's easily fixed. I won't be responding to your requests for an opinion again. This has happened before... Nev No offense intended Nev but I suggest you go back & read my question which had nothing to do with automotive brake fluid in the Grove system.
