Guest Guest Posted May 26, 2006 Posted May 26, 2006 Hey, Just wondering if there is a minimum numbers of hours a year you need to fly with the RAA pilot certificate before having to fly with a CFI, thanks
pylon500 Posted May 26, 2006 Posted May 26, 2006 Looking up the Op's Manual, it's a little vague?Check sections 2.8,2.9 and 2.13.Basic jist seems to be as long as you did a renewal flight within two years ago, you can still fly!But the reality is that if you rock up to a flying school or club to hire and fly, unless your logbook shows flying within the last four to six weeks, they'll all want you to do a check ride with at least a senior instructor.If you drive up to an airfield with your own aircraft, at least one of the local operators should ask to see your logbook and rego just for their own liability's sake.Once again the reality is, if you are not known at the field, lots of people will look over your plane, your rego card and someone will no doubt want to look at your logbook again.If you complain too much they may ask you to leave the field, or they will make sure they have a witness or two of them saying to you "We suggest you don't fly, and if you do we take NO responsibility for you"As for your actual question, I guess you only have to do one hour every two years, But it will be with a CFI!
