CLAYT Posted September 5, 2022 Posted September 5, 2022 Has anyone on this site turbocharged a 912 uls?
409tonner Posted September 6, 2022 Posted September 6, 2022 Hi Clayton have a look at edge performance on the web .
Thruster88 Posted September 6, 2022 Posted September 6, 2022 Brumby Aircraft have done done some. https://www.planesales.com.au/details/Listing/Single-Engine-Propeller/8770/2022-Brumby-610-Evolution-Aircraft?utm_source=ListingID-8770&utm_medium=banner&utm_campaign=2022 Brumby 610 Evolution Aircraft
CLAYT Posted September 8, 2022 Author Posted September 8, 2022 Have found the people I’m looking for thanks all
RFguy Posted September 13, 2022 Posted September 13, 2022 (edited) if you want to apply a turbo , the an old 80hp rotax is what you want (9:1) , not a 912ULS (100hp) because the compession is too high to be useful for the 100hp. (in my opinion) Yes, 100hp can be turboed but it involves either spacers for the cylinders to reduce the compression, or different piston/bore kits. I mean sure you can turbo with 10.8, but I think I'll leave that one to when I have a full house in the hand and a joker. what I dont know is if the gearbox is uprated for the 100hp , or is it the same identical gearbox in the 80hp, that might have a bearing. From what I read in forums is that essentially, the TBO of the gearbox goes down as you push the friendship with it up. Looking in the rotax illustrated parts catalog, I could find no difference between 912UL, ULS and the 914 in the propellor gearbox , nor the clutch except there is a different casing for the 914 I think. certainly recently there was an SI for 914 exhaust valves which of course take a canning with the turbo. https://legacy.rotaxowner.com/si_tb_info/serviceinfo/si-914-030.pdf Edited September 13, 2022 by RFguy 2
Kyle Communications Posted September 14, 2022 Posted September 14, 2022 There is a guy in Melbourne who does a lot of 912ULS turbo conversions. Mainly for the gyro guys. Everything I have seen he has all good reports Mark 1
CLAYT Posted September 19, 2022 Author Posted September 19, 2022 On 14/09/2022 at 1:55 PM, Kyle Communications said: There is a guy in Melbourne who does a lot of 912ULS turbo conversions. Mainly for the gyro guys. Everything I have seen he has all good reports Mark Expand Thanks Mark I have been talking to him👍
Kyle Communications Posted September 19, 2022 Posted September 19, 2022 I asked him about doing a turbo for a big bore kitted 912 ULS which is a base power of 114hp turbo would bring it up another 15 or 20hp. He hasnt done one like that. Mark
CLAYT Posted September 19, 2022 Author Posted September 19, 2022 On 13/09/2022 at 10:22 AM, RFguy said: if you want to apply a turbo , the an old 80hp rotax is what you want (9:1) , not a 912ULS (100hp) because the compession is too high to be useful for the 100hp. (in my opinion) Yes, 100hp can be turboed but it involves either spacers for the cylinders to reduce the compression, or different piston/bore kits. I mean sure you can turbo with 10.8, but I think I'll leave that one to when I have a full house in the hand and a joker. what I dont know is if the gearbox is uprated for the 100hp , or is it the same identical gearbox in the 80hp, that might have a bearing. From what I read in forums is that essentially, the TBO of the gearbox goes down as you push the friendship with it up. Looking in the rotax illustrated parts catalog, I could find no difference between 912UL, ULS and the 914 in the propellor gearbox , nor the clutch except there is a different casing for the 914 I think. certainly recently there was an SI for 914 exhaust valves which of course take a canning with the turbo. https://legacy.rotaxowner.com/si_tb_info/serviceinfo/si-914-030.pdf Expand Thanks RF I realise I would have to change the compression ratio👍 1
CLAYT Posted September 19, 2022 Author Posted September 19, 2022 On 19/09/2022 at 2:58 AM, Kyle Communications said: I asked him about doing a turbo for a big bore kitted 912 ULS which is a base power of 114hp turbo would bring it up another 15 or 20hp. He hasnt done one like that. Mark Expand What I can gather he has done 30 to 40 of the 140hp upgrades
Kyle Communications Posted September 19, 2022 Posted September 19, 2022 He isnt sure about the big bore version..he offered me a kit but I would probably have to do other stuff to it...getting the compression right too is another thing so would need sparer rings for the heads to lower compression Our conversation is below. But I have had good feedback from Gyro guys about his conversions. I have supplied my replacement CDI's to the gyro guys I gather you want to put it in a Hornet. I had a guy drop into my farm with a Hornet with a std 912ULS..the perfomance wasnt that great..it does need about 20 more horses and it would be a great aircraft Hi Mark, This would be a one off. I have only done testing on the standard 100 hp with the turbo. Also other considerations like the bore diameter and the current compression ratio would have to calculated. Other companies won't turbo the big bore so I couldn't guarantee how well the engine would hold up. Can you give me some more info on the engine like cylinder bore diameter compression ratio and if the camshaft is standard? Thanks Steve Hi Steve The bore is 4mm bigger and is 1484 cc once fitted. I believe the compression ratio is the same. The camshaft is std. Its basically just replacing the pots and pistons which are 4mm bigger in size. I had the crank welded and the engine has been totally balanced. I understand the differences in piston load etc although the piston speed is the same as there is no difference in the stroke of course. Hi Mark. I could offer you a turbo conversation kit If you have a mechanic to do the conversion. there may be differences in some parts you would have to work out as you go.
RFguy Posted September 19, 2022 Posted September 19, 2022 Hi ClayT. The 912ULS on my J230 will be down quite a bit in 7500' cruise on the Jab 3300, so I am stiffing around for options, also. I'm thinking a 10.8:1 big bore kit will pick up almost all of the slack, and the extra bit picked up with the lower prop RPM slight efficiency advantage. The big bore kits from some vendors can be ordered in lower compression.
