sfGnome Posted November 23, 2022 Posted November 23, 2022 RfGuy, I enjoy reading your calculations on a myriad of subjects, but I have one really important question. When do you find the time to do your paying work? 😄 (Keep it up!) 2 1
skippydiesel Posted November 23, 2022 Posted November 23, 2022 4 hours ago, facthunter said: You have to be taught to do a proper scan.. Nev True! and it will significantly improve on the untrained BUT there is no getting away fro the truism that the human eye is about as good for flying as the human body. There is hope however - the untiring improvements (& miniaturisation ) of cost effective technology, will eventually see the installation of TECAS type technology in all flying machines. 2
RFguy Posted November 23, 2022 Posted November 23, 2022 (edited) It's clear that the flashtube strobes are powerful emitters. And quite efficient. But the reading I did that steady lights requires some dwell time in a sector of the sky to recognise, whereas the pulses light source could grab your attention quickly was an interesting find. It's a good reason to pulse your light source . I need to replace the beacon on the tail of my J230. GA Tail top Flashtube strobes vary between 25 and 50 Joules. both good numbers Consulting FAA guidance and rules : https://www.ecfr.gov/current/title-14/chapter-I/subchapter-C/part-25/subpart-F/subject-group-ECFR0cb7970b9d1fd5f?toc=1 interesting, 400 candela/flash rate (not much) (of red or white required on axis. overlapping colours ot be synchronized. yeah all makes sense. Interesting #2- for a strobe, 400 candela and 1mS duration and 1Hz flash rate and 20 deg beam angle = ~ 500klms say again, we're up in that 1 million lumens department for narrow pulses. Given that the eye can detect infintestimal pulse width- just as long as enough photons get into the collection bucket to trigger. So, mostly its a battle against the daylight, hence the need for a few million peak lumens. Edited November 23, 2022 by RFguy 1
facthunter Posted November 24, 2022 Posted November 24, 2022 Beware the HUN in the sun. With sunlight in the background NO light source is going to show up really. and you can't LOOK into the sun. Landing towards it should be avoided near sundown. nev 2 1
