RFguy Posted February 27, 2023 Posted February 27, 2023 Skippy see if it occurs with a low vapour pressure fuel such as AVGAS LL100. Put some additive in it (Decalin runup) if concerned about buildup just for one tank of fuel.
skippydiesel Posted February 27, 2023 Author Posted February 27, 2023 On 27/02/2023 at 12:50 AM, RFguy said: Skippy see if it occurs with a low vapour pressure fuel such as AVGAS LL100. Put some additive in it (Decalin runup) if concerned about buildup just for one tank of fuel. Expand Thanks RFguy Is this with reference to Nev's possible fuel bubbles/boiling? I see the logic - floats may perform better thereby more reliably keeping fuel level below "spill" height - no fuel in catch cans. As I have no intention of using AvGas (except when ULP 95-98 unavailable) I think I would rather go: Monitor under cowl temperature - have the system in place. Up to now has just been for the occasional look/check - will take a more systematic approach over the next few flights. Findings may guide next step(s) Check/adjust clearance of brass armature/float bracket (float acts on, to open close inlet valve/needle) - should be 0.5mm ("Spacing on the 912 Series: 0.4 to 0.5 mm"). Possible manufacturing assembly error. Check float needle valve condition at the same time as above
