Kyle Communications Posted March 29, 2023 Posted March 29, 2023 I was put onto them by another guy who is running them. I have fitted these to 2 new engines and they fit perfectly..hopefully after this weekend I can tell you if at least one of them works when I start the engine on this rebuilt big bore kit engine 1
facthunter Posted March 29, 2023 Posted March 29, 2023 Even the gasket thickness affects these things. Every bit of care is required. Nev 1
Kyle Communications Posted March 29, 2023 Posted March 29, 2023 All looked and measured exactly the same Nev 2
danny_galaga Posted March 29, 2023 Author Posted March 29, 2023 27 minutes ago, Kyle Communications said: I was put onto them by another guy who is running them. I have fitted these to 2 new engines and they fit perfectly..hopefully after this weekend I can tell you if at least one of them works when I start the engine on this rebuilt big bore kit engine Looking forward to hearing more 🙂 I may buy one or two and store in my garage for the next five year replacement.
facthunter Posted March 29, 2023 Posted March 29, 2023 Could easily be a shelf life regarding the diaphragm. For automotive work that would never be mentioned. The Bodies are usually Diemetal with high zinc content and age. (Buckle and go brittle). Advantage is you can cast the threads and other detail. Nev
danny_galaga Posted March 29, 2023 Author Posted March 29, 2023 5 minutes ago, facthunter said: Could easily be a shelf life regarding the diaphragm. For automotive work that would never be mentioned. The Bodies are usually Diemetal with high zinc content and age. (Buckle and go brittle). Advantage is you can cast the threads and other detail. Nev Yes, that has crossed my mind, that the rubber might perish just sitting there. I will investigate. My garage is cooler than my house, so heat shouldn't be an issue
facthunter Posted March 29, 2023 Posted March 29, 2023 Nearly see us out, anyhow. Put it in a welded plastic bag .Nev
danny_galaga Posted March 29, 2023 Author Posted March 29, 2023 From this it implies Rotax themselves say 48 month shelf life https://www.rotax-owner.com/en/912-914-technical-questions/9671-912-fuel-pump-shelf-life?start=0
Kyle Communications Posted April 2, 2023 Posted April 2, 2023 Well I did the first start on Mabels engine..it has the fuel pump I showed on it and it worked fine 1 1
danny_galaga Posted April 3, 2023 Author Posted April 3, 2023 22 hours ago, Kyle Communications said: Well I did the first start on Mabels engine..it has the fuel pump I showed on it and it worked fine Looks like you've avoided the RO-tax 😄
pmccarthy Posted April 4, 2023 Posted April 4, 2023 42 minutes ago, facthunter said: Short ground runs are not a good idea. Nev It will be a short run as he is towing the ute. 2
Kyle Communications Posted April 4, 2023 Posted April 4, 2023 I ran the engine until the oil got to over 55 degC the video was edited Too boring otherwise 3
