Marty_d Posted December 17, 2023 Posted December 17, 2023 Thanks Bob. Microair M760, which I don't think has a built in intercom (happy to be corrected!) I'd like to put the jacks on the centre front of the baggage area, but having just installed the seat cushions there's no room between them there. So will have to be on the baggage area "floor" just aft of the seats. I definitely want them in the middle as opposed to the outside, as you said for ingress/egress you're not getting tangled in leads.
IBob Posted December 17, 2023 Posted December 17, 2023 Does the M760 have VOX mode? Is that not intercom? I'm no expert on this but others here will know. Maybe consider putting the jacks in baggage front centre roof as per the South Africans: they are practical outfit, much of what they do makes sense. 1
RFguy Posted December 18, 2023 Posted December 18, 2023 BTW yesterday I installed a FUNKE ZATR833S in a friend's aircraft. It is superb ! easy to setup, everything is controllable, adjustable from the panel, wiring it is highly adaptable, real nice kit . good ext audio input options, adjustable sidetone level s indpenendent of mic gains etc dont forget to set it to 25k channel spacing once installed. sounds good on air, also. https://www.ozpilot.com.au/product/funke-zatr833s-vhf-transceiver/?utm_source=Google Shopping&utm_medium=cpc&utm_campaign=Ozpilot Products&gclid=CjwKCAiA1fqrBhA1EiwAMU5m_0bZoX14nmGoZrjP0sMxGlTzcim12-uPIdLPcLhAhz692YI7X07znhoCq1MQAvD_BwE 1
IBob Posted December 18, 2023 Posted December 18, 2023 RFguy can you suggest where to source headphone jacks? Are we best to go to aviation outlets, or is the quality similar regardless? Thanks.
Marty_d Posted December 18, 2023 Posted December 18, 2023 Clear Prop sell them. I can certainly fabricate a box/panel to mount them in. I assume I need 2 each of the headset jack and microphone jack? 1
RFguy Posted December 18, 2023 Posted December 18, 2023 this is the easiest https://www.flightstore.com.au/aviation-headsets/plugs-jacks or, buy from clearprop, ozpilot, or mobileone .. I get mine from Mouser but you need to know all the cryptic Switchcraft numbers. 1
Marty_d Posted December 18, 2023 Posted December 18, 2023 (edited) Thanks RF - Clear Prop were basically the same price, so went with Ian. Edited December 18, 2023 by Marty_d 2 1
