Yep,  although they are 13mm thick.  I've only got 16mm total on the threads and I need 6 for the top nuts and another 1 for the bracket, leaving 9mm.  So I reckon Blueadventures is right and I should just get some scrap 6mm ally and tap it out.
I have used two nuts locked on a thread in the lathe and  carbide tools to cut down nuts.  This system keeps the tool away from the jaws and an expensive collission. I have also made nuts using hex bar in the lathe.  Beware of cheap Chinese dies I have bought some online that don't cut a thread that will connect to a standard bolt.
One fastener supplier that sometimes has the odd fastener is Lee Bros of North Parramatta they are an outside chance.  But if you find that they have one I will buy it and post it to you.
  • Like 3
My go to fastener supplier for non-aviation spec stuff is www.bolt.com.au at Smeaton Grange, which is near Camden NSW
They list an M22 x.15 locknut for $7.80 Part No BLNMF22x1.5
There is a store in Dandenong.
WWW.BOLT.COM.AU
Find your nearest local Bolts & Industrial Store.
90% of the axial load of a bolt is taken in the first  one and a half threads. A bolt with a lower modulus of elasticity make load 90% in a slightly larger number of threads.  So lock bolt material would not worry me so much.  But the galvanic action of dissimilar metals would worry me.
The oil cooler threads are aluminum themselves,  I'm pretty sure.
Posted (edited)
Taping alloy is not good , as it binds in the tap thread's.
BEST To get' HEX ' BAR  ,then you don't have ' galvanic problems.
spacesailor
Oops read that last post after I hit send . Make them all alloy .
Edited by spacesailor
A little more !
That's the logical thing to make them from then. Duralumin (TM) is a stronger alloy. .  Nev
  • 5 weeks later...
Dis I mis the obvious supply solution in my very quick read through - E mail B Flood with the following part number for an availability & price.
Rotax Oil Radiator parts - 4 nuts on part number 242873
2 N 242873 ..2 HEX NUT M22x1.5 (4)h (4)h (4)h (4)h (4)h (4)h (4)h
He did source some.  I was actually sorting stuff at the hangar today and unwrapped some bubble wrap and it contained a set of oil cooler connections (items in image except the 1 & 5 parts).  Were from an oil cooler we needed 8 months ago.
44 minutes ago, Blueadventures said:
Marty if your ones don't fit or something let me know.
Thanks Mike, will do. They're coming from China so I'm not expecting them for a while.
