Pat Posted May 27, 2023 Posted May 27, 2023 For lack of a better category, posting this here. Is there a helmet that is suitable for flying that allows wearing typical headsets underneath (i.e. the headset is not fixed integrated into the helmet)? Thank you!
turboplanner Posted May 28, 2023 Posted May 28, 2023 10 hours ago, Pat said: For lack of a better category, posting this here. Is there a helmet that is suitable for flying that allows wearing typical headsets underneath (i.e. the headset is not fixed integrated into the helmet)? Thank you! Problem is any object inside the helmet shell becomes embedded in your skull. Same with objects on the outside like cameras. There was a NASCAR crash a few years ago, looked fairly routine, but the car had a camera mounted in the roll cage and it took more than 7 hours to get him out. Specialist brain surgeons were called and operated on him to extract the camera. 1 1
skippydiesel Posted May 28, 2023 Posted May 28, 2023 Just Google Aviation Helmets - quite a few different concepts - one may suit you. 1
Pat Posted May 28, 2023 Author Posted May 28, 2023 Any lesser known brands out there besides the usual (expensive) suspects?
skippydiesel Posted May 28, 2023 Posted May 28, 2023 $71 - I guess it depends on your budget https://www.smiffys.com.au/products/top-gun-deluxe-helmet?currency=AUD&variant=31867417067581&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gad=1&gclid=Cj0KCQjw98ujBhCgARIsAD7QeAi7-F3WUuGQEBs-MsnxgXoFQ-Lh_aVtjJ-2x2OLHRA4xKuVd4EtwO4aAhDtEALw_wcB $795 for DC's - last quote I had for DC headset was about $1800 https://www.flightstore.com.au/david-clark-k10-helmet-kit?gclid=Cj0KCQjw98ujBhCgARIsAD7QeAgmY7ym1z4dW1SAstix4fdFoLHQVu1MU1pXOWl8pr6gW8JPgvMbGb4aAoluEALw_wcB
Old Koreelah Posted May 29, 2023 Posted May 29, 2023 Pat if you have limited means and some skills, build your own. I bolted my DC headset to a fibreglass bicycle helmet. 1
Pat Posted May 29, 2023 Author Posted May 29, 2023 8 hours ago, Old Koreelah said: Pat if you have limited means and some skills, build your own. I bolted my DC headset to a fibreglass bicycle helmet. Interesting, do you have some pictures or a build log? Thanks
Old Koreelah Posted May 29, 2023 Posted May 29, 2023 Sure anyone could improve on my ruff-as-gutz workmanship. The box mounted behind holds the noise-cancelling unit. Also in the pic is my pair of flying gloves; on the advice of an old Aggie mate, I wear them religiously, with two fingers cut off for iPad use, etc. 1
Pat Posted May 30, 2023 Author Posted May 30, 2023 On 28/5/2023 at 2:29 AM, turboplanner said: Problem is any object inside the helmet shell becomes embedded in your skull. Same with objects on the outside like cameras. There was a NASCAR crash a few years ago, looked fairly routine, but the car had a camera mounted in the roll cage and it took more than 7 hours to get him out. Specialist brain surgeons were called and operated on him to extract the camera. Not sure I understand. The camera was mounted in the car. The driver wore a helmet. He hit the camera with the helmet, and it protruded into his brain? Must have been a really crappy helmet? Formula 1 helmets are bullet proof...
turboplanner Posted May 30, 2023 Posted May 30, 2023 7 minutes ago, Pat said: Not sure I understand. The camera was mounted in the car. The driver wore a helmet. He hit the camera with the helmet, and it protruded into his brain? Must have been a really crappy helmet? Formula 1 helmets are bullet proof... The race car structure is not just based on a helmet; that's component 1. Component 2 is a roll cage or structure designed to prevent collapse or intrusion towards the driver. Component 3 is a safety harnes which restrains the driver from coming into any contact with the roll cage/structure. The helmet then only has to protect against flying objects. Above a certain G force, even with this in place, a driver can die from the brain hitting the skull in big G Force car impacts, i.e. drivers have died without a mark on them in Toyota Land Cruisers fitted with bull bars due to the sudden stop. You haven't told us what the application is that requires a helmet; just that you want to feel safer in normal operations, or high risk operation such as crop spraying. Aircraft operations are different to race/road cars. There's a very good thread on it on this site if you want to do some searching. 1
Pat Posted May 30, 2023 Author Posted May 30, 2023 6 minutes ago, turboplanner said: The race car structure is not just based on a helmet; that's component 1. Component 2 is a roll cage or structure designed to prevent collapse or intrusion towards the driver. Component 3 is a safety harnes which restrains the driver from coming into any contact with the roll cage/structure. The helmet then only has to protect against flying objects. Above a certain G force, even with this in place, a driver can die from the brain hitting the skull in big G Force car impacts, i.e. drivers have died without a mark on them in Toyota Land Cruisers fitted with bull bars due to the sudden stop. You haven't told us what the application is that requires a helmet; just that you want to feel safer in normal operations, or high risk operation such as crop spraying. Aircraft operations are different to race/road cars. There's a very good thread on it on this site if you want to do some searching. Thanks for the explanation, appreciated! I still don't understand how the gopro ended up in the driver's skull? Anyway, excellent point raised about objects within the helmet, thank you! I'll do some searching for the helmet thread. Application is indeed I want to feel safer in normal operations (= in my flying gardenshed ultralight plane). Thank you!
Old Koreelah Posted May 30, 2023 Posted May 30, 2023 2 hours ago, skippydiesel said: Tell us about the fingerless gloves ??? I wanted to look like Steptoe! Having a couple of fingers free sure helps with iPad, switches, etc. In case of a prang, the leather gloves might reduce injuries while smashing my way out. 1
skippydiesel Posted May 30, 2023 Posted May 30, 2023 49 minutes ago, Old Koreelah said: Iwanted to look like Steptoe! Having a couple of fingers free sure helps with iPad, switches, etc. In case of a prang, the leather gloves might reduce injuries while smashing my way out. 😁I like it but the reverence sure dates you (not that I would know)😆 You are supposed to unlatch your cockpit locking mechanism well befog the "Prang" 1
Old Koreelah Posted May 30, 2023 Posted May 30, 2023 1 hour ago, skippydiesel said: You are supposed to unlatch your cockpit locking mechanism well befog the "Prang" Yes, but on impact a forward-sliding canopy will do what it wants. Flipping over is a danger, so my canopy might end up on the ground, unable to slide. Smashing out through the acrylic is my only hope.
skippydiesel Posted May 30, 2023 Posted May 30, 2023 35 minutes ago, Old Koreelah said: Yes, but on impact a forward-sliding canopy will do what it wants. Flipping over is a danger, so my canopy might end up on the ground, unable to slide. Smashing out through the acrylic is my only hope. Good luck with "Smashing out through the acrylic " Assuming you have suffered no physical damage to ourselves, you are hanging outside down, in a confined space (cockpit), your ability to exert force/blows on anything at all, will be severely compromised. If you are injured .....................???????-
Old Koreelah Posted May 30, 2023 Posted May 30, 2023 5 hours ago, skippydiesel said: Good luck with "Smashing out through the acrylic " Assuming you have suffered no physical damage to ourselves, you are hanging outside down, in a confined space (cockpit), your ability to exert force/blows on anything at all, will be severely compromised. If you are injured .....................???????- I actually practiced that when building the beast, but quite a few years later I’m not nearly as good at wriggling through confined spaces.
spacesailor Posted May 30, 2023 Posted May 30, 2023 The ' brain hitting the skull , was what dr's have said , would happen a over 80 mph bikes hitting a wall. Or 40 mph in a heading smash , against a 40 mph vehicle. But the mashed brain greymatter will be contained. All those years ago ! . spacesailor
spacesailor Posted May 31, 2023 Posted May 31, 2023 My 40 mph against an oncoming vehicle doing 40 mph . Headon smash of two vehicles, both doing the same 40 mph = 80 mph . Better I hope
facthunter Posted May 31, 2023 Posted May 31, 2023 If they are equal velocity and mass they do the same as hitting a brick wall. They go from 40 MPH to zero. Nev
rgmwa Posted May 31, 2023 Posted May 31, 2023 The energy involved in the head-on between two cars colliding at 40 mph is half that of one car travelling at 80 mph. I'd much rather be in the head-on. 1 1
BrendAn Posted May 31, 2023 Posted May 31, 2023 On 30/05/2023 at 10:45 AM, Pat said: Thanks for the explanation, appreciated! I still don't understand how the gopro ended up in the driver's skull? Anyway, excellent point raised about objects within the helmet, thank you! I'll do some searching for the helmet thread. Application is indeed I want to feel safer in normal operations (= in my flying gardenshed ultralight plane). Thank you! i can't help with nascar accidents but microavionics make an excellent microlight flying helmet that slips over a standard headset not too expensive , i think 8or900 last time i looked. lots of options with visors etc. mendehlsons in melbourne are agents and do mail order. 1
