rgmwa Posted June 27, 2023 Share Posted June 27, 2023 On 24/6/2023 at 5:59 PM, skippydiesel said: Okay - seems I was wrong. Still I would very much prefer to start a Rotax 912ULS using the starter motor That was an 80hp UL with no slipper clutch in the video. A 100hp ULS would be more challenging. 1 1 Link to comment Share on other sites More sharing options...
kgwilson Posted June 27, 2023 Share Posted June 27, 2023 I have a twin piston compressor for inflating tyres. It will inflate a completely flat tyre to 40 PSI in a couple of minutes. It came with a cigarette lighter fitting as well as aligator clips for direct battery connection. I tried the cig lighter fitting & it blew the fuse straight away. It uses about 25 amps. Any mob that thinks their jump starter can be used via a cig lighter socket has rocks in their heads. Don't even think of buying anything they try to sell. There are heaps of jump starters on Ebay from $35.00 to about $300.00. Lots around the $100.00 mark. Check for a money back guarantee and Australian supplier plus customer ratings. The lithium packs are pretty light & they also often have a torch & various USB outlets so can be used to charge your phone, SE2 and other devices. Some also have wireless charging. 1 1 Link to comment Share on other sites More sharing options...
wanabigaplane Posted July 30, 2023 Share Posted July 30, 2023 YES !! Get a jump starter. On my recent trip to central Australia my 3300 Jab motor would not turn over fast enough to start on the really cold mornings. I was extremely thankful that before the trip I had installed a heavy duty pair of cables with an Anderson plug INSIDE the cabin. I did not have to remove the cowl to add the jump starter - I did not even have to get out of the aircraft !! During the trip my rectifier failed and became intermittent so that on the last day, at a mid day stopover to get fuel, the battery did not have enough punch to turn the motor over. The jump starter really saved my bacon. 1 2 Link to comment Share on other sites More sharing options...
BrendAn Posted July 30, 2023 Share Posted July 30, 2023 7 hours ago, wanabigaplane said: YES !! Get a jump starter. On my recent trip to central Australia my 3300 Jab motor would not turn over fast enough to start on the really cold mornings. I was extremely thankful that before the trip I had installed a heavy duty pair of cables with an Anderson plug INSIDE the cabin. I did not have to remove the cowl to add the jump starter - I did not even have to get out of the aircraft !! During the trip my rectifier failed and became intermittent so that on the last day, at a mid day stopover to get fuel, the battery did not have enough punch to turn the motor over. The jump starter really saved my bacon. that turned out to be a great investment. Link to comment Share on other sites More sharing options...
