I was reading this . So if the upper level of the transition layer is FL115 on the day , can I fly at FL115?
Because, by the definition I am not flying inside the transition layer at FL115 . (FL100 to FL115 in this example)
about as good as it gets with the Archer is about a DA of 11500.
Email CASA for a definitive answer.
If the Transition level was FL115, the area QNH could be as low as 997 hPa, in Australia the weather on the ground would be pretty nasty. Think of the August winds.
The transition altitude (TA) is the altitude above sea level at which aircraft change from the use of local barometer derived altitudes to the use of settings based on 1013.5 hPa. When operating at or below the TA, aircraft altimeters are usually set to  (QNH) Above the TA, the aircraft altimeter pressure setting is normally adjusted to the standard pressure setting of 1013.25 hectopascals. The transition layer is the airspace between the transition altitude and the transition level. According to these definitions the transition layer is 0–500 feet  thick.
Looking at things from above the transition altitude, an aircraft flying at the 'transition level', in this example FL115, would not have adequate separation from traffic flying on QNH at the transition altitude. Instead, the lowest usable "'flight level'" is the transition level plus 500 ft.
Consider the TA to be a line in the sky. Below it, QHN prevails. Above it 1013.25 prevails. The connection between "transition altitude" (TA), "transition layer" (TLYR), and "transition level" (TL) is
TL = TA + TLYR
But if you are flying at the 10k' TA, you have altimeter QNH = 1013.
(temp effects aside)
If an  aircraft was flying with altimeter set for  1013 and QNH = 1013 , at an indicated 9500' for they are flying at 9500 PA.
If the aircraft was flying  with altimeter set for  1013 and QNH actual = 997, (IE reads higher than you really are because air pressure is lower)  at an indicated 9500' they are flying at ~ 9500-440'. = ~9060' PA
If the aircraft was flying  with altimeter set for  1013 and QNH actual = 1030, (IE reads lower than you really are)  at an indicated 9500' they are flying at ~ 9500+467'. = ~ 9967' PA
umm is that right ?
I have emailed CASA . We'll see what I get back. Generally, a 2D defined medium  has boundaries to define it and these are not necessarily inclusive.
You can cruise at the Transition Altitude, or the Transition Level, but not within the Transition Layer.  AIP ENR 1.7.2.1.4
As you've already noted, the layer thickness may vary depending on actual QNH, which will affect whether you can cruise at FL110-FL130, but like, for example, where Class C overlays Class G at 8,500, you can cruise at 8,500 and you're still in G.
You are supposed to have readjusted your references before you descend out of or climb through the Transition layer. . Within  that piece of sky people will be in various stages of resetting and cross checking so positive separation cannot be  achieved.    Nev
Posted (edited)
seems there has been continuous change of this chapter in the AIPs
in 2017  there was a section descibed as "Limitation" .. - and it implied NO to my question -  IE that  you cannot cruise at FL110 if the upper boundary was FL110 for the day.
BUT !!!
but not in the 2022/- This has been replaced with TABLE 5 - B
Table 5 indicates that FL115 is available  unless QNH < 997
So this is different - ish
Edited by RFguy
BUT !!!
So this is different !
That's the real CASA disease; it happens on so many subjects; not an issue if you're flying every week, but a PIA for occasional trips.
Posted (edited)
Change is OK.
The section of the AIP on this (1.7)  from 2017 was a bit of a dogs breakfast. the usual translation from  legislation to plain language. The CASA legislation  is full of "statement followed by a plethorea of exceptions to that statement " !
that's sort of how the previous AIP section was written.
This is better . multiple passes of it and I can be fairly competent of interpreting it as the upper boundary layer (spelt out by the Area QNH)  is NOT part of the transition buffer layer.
IE if the buffer is FL100 to FL115,  (Area QNH >=997 and < 1013 then you can cruise at FL115.
Edited by RFguy
BUT !!!
Could be because they're replaced that chapter with a pretty new graphic in the latest AIP?
Posted (edited)
The unavailability of FL110 for cruise when the Area QNH is less than 1013 is due to the Transition Layer becoming squished in with the low QNH.
If the Area QNH is less than 1013hPa, the vertical distance between A100 and FL110 is less than 1000ft (squished).
If the Area QNH is 1013hPa (1013.25), the vertical distance between A100 and FL110 is 1000ft.
If the Area QNH is Greater than 1013hPa, the vertical distance between A100 and FL110 is greater than 1000ft (fattened).
Due to the squishing of the Transition Layer when the QNH is low (Transition Altitude and Transition Level less than 1000ft apart), cruising at FL110 is not available with an Area QNH less than 1013hPa. This squishing continues to happen as the Area QNH lowers, at less than 997hPa, there will be less than 1000ft between A100 and FL115.
Example QNH table below:
For QNH 1013 the Transition Layer is 1000ft thick. The higher the QNH goes, the thicker the Transition Layer becomes: at QNH 1017, the Transition Layer is 1120ft thick.
As the QNH lowers, the Transition Layer becomes compressed, so a 'correction*' is applied. At QNH 1012, there is only 970ft between A100 and FL110, therefore, cruising at FL110 is no longer available and a 500ft 'correction buffer*' is added to the Transition Layer to ensure there is at least 1000ft between A100 and the next available Flight Level (FL115).
The compression continues as the QNH lowers, and at QNH 996, there is 990ft between A100 and FL115, so the next 'correction*' value kicks in, FL115 is no longer available and the next available Flight Level is FL120.
So, on a low QNH day, if the Area QNH is less than 997, cruising at FL115 is not available because there is less than 1000ft between A100 and FL115.
If there were no corrections* applied to the Transition Layer, by the time the QNH reaches 979hPa, altitude A100 would be 20ft above flight level FL110.
(*not an actual term, but I couldn't think of a better one)
QNH Compression Correction Transition Altitude Layer Thickness Transition Level
1017 1120 0 A100 1120 FL110
1016 1090 0 A100 1090 FL110
1015 1060 0 A100 1060 FL110
1014 1030 0 A100 1030 FL110
1013 1000 0 A100 1000 FL110
1012 970 +500ft A100 1470 FL115
1011 940 +500ft A100 1440 FL115
1010 910 +500ft A100 1410 FL115
1009 880 +500ft A100 1380 FL115
1008 850 +500ft A100 1350 FL115
1007 820 +500ft A100 1320 FL115
1006 790 +500ft A100 1290 FL115
1005 760 +500ft A100 1260 FL115
1004 730 +500ft A100 1230 FL115
1003 700 +500ft A100 1200 FL115
1002 670 +500ft A100 1170 FL115
1001 640 +500ft A100 1140 FL115
1000 610 +500ft A100 1110 FL115
999 580 +500ft A100 1080 FL115
998 550 +500ft A100 1050 FL115
997 520 +500ft A100 1020 FL115
996 490 +1000ft A100 1490 FL120
995 460 +1000ft A100 1460 FL120
994 430 +1000ft A100 1430 FL120
993 400 +1000ft A100 1400 FL120
992 370 +1000ft A100 1370 FL120
991 340 +1000ft A100 1340 FL120
990 310 +1000ft A100 1310 FL120
989 280 +1000ft A100 1280 FL120
988 250 +1000ft A100 1250 FL120
987 220 +1000ft A100 1220 FL120
986 190 +1000ft A100 1190 FL120
985 160 +1000ft A100 1160 FL120
984 130 +1000ft A100 1130 FL120
983 100 +1000ft A100 1100 FL120
982 70 +1000ft A100 1070 FL120
981 40 +1000ft A100 1040 FL120
980 10 +1000ft A100 1010 FL120
Edited by Kieran17
Added Transition Level and Altitude to table
The only thing you will get back will be a reference for which AIP/Regs to look at. CASA doesn't give definitive answers.
CASA IF you can understand our latest rules let us know and we will look into it.. A lot of it is LAWYER SPEAK.  and needs' interpretation.. It's ever been thus.  Nev
It is significant that  at least in the AIP, every couple of years there has been a change of the way they spell it out.. at least 4 times since 2011.....
Now, the most recent AIP, that I think I can interpret with the intention of the text.  But they did change it since 2017, presumably people like me writing in and querying.
The last time I flew above 10,000' in an unpressurised aircraft without supplemental oxygen was 1983 in PNG where, if my memory serves the transition level was higher due to there being lots of mountains exceeding 10,000'. I recall my mate saying you weren't allowed to plan to fly above 10,000' without oxygen, but once in the air you could amend plans to do so. I needed to one day and it was common there.
Just had a look at the Part 91 MOS and my interpretation is no need for oxygen as long as the cabin pressure does not exceed FL 125 for more than 30 minutes. Did I miss anything?
MOS26.43 Supplemental oxygen (MOS 26.43) An aircraft must carry sufficient supplemental oxygen as described in Table 25. Fitted or carried supplemental oxygen, must be able to be stored and dispensed to the crew and passengers. Flight crew members must use supplemental oxygen in accordance with the supply requirements set out in Table 25.
US has a different level for 02 to us here. Their's is 2000ft higher. How it affects you depends on age, fitness and being used to altitude. 65 t0 69 I regularly flew to Lae from POM on a DC4 which had oxygen  available. to crew.  The LSALT on the way back is 17,400 and I can't recall anyone using the masks but I once was asked by a medico why My red cell count was so high and apparently it was to do with flying unpressurised.  Nev
  • Informative 2
