RFguy Posted July 10, 2023 Posted July 10, 2023 (edited) so be it , prefer none than delayed or rely on a system that may have high latencies. radio should catch others... mobile data is very low reliability over anywhere serviced by multiple base stations and or base stations that are busy. I will see RPT (they have ADSB without ozrunways) , and many GA. if the others dont have at least a SE2, not much I can do except listen in the radio. down the track I might add a interferometer receiver which can determine likely location of transponder only aircraft by trilateration and triangulation. Edited July 10, 2023 by RFguy 1
kgwilson Posted July 10, 2023 Posted July 10, 2023 There is not much point seeing traffic in the wrong position on the screen that has already gone past you. 1 1
facthunter Posted July 11, 2023 Posted July 11, 2023 Like a back seat driver telling you that you should have turned at the intersection back there. In this business 10 seconds is forever. TCAS is analysing the conflicting traffic and gives avoidance advice to both aircraft. In congested traffic, I doubt it could handle it. Nev 1
RFguy Posted July 11, 2023 Posted July 11, 2023 In my case of having traffic to my right , turning right would have meant the collision occurs a few hundred milliseconds earlier. My best option would have been to pull up since. I was below or at Va. Now, if they had ALSO gone right right that would be OK if I had also gone right. if they had gone right down , would have been best for me to go up left.
facthunter Posted July 11, 2023 Posted July 11, 2023 If the object you are concerned with is stationary in your window, you will collide. A non moving object in your field of view is also harder to see. Nev 1
