rhtrudder Posted August 12, 2023 Posted August 12, 2023 Quote Noticed a soft compression one one cylinder so ran through a leak down test sat the gauge on 80 , three read 77psi but the sick one was down to 75 psi , I guess not a lot of difference, could hear a faint bubble in the oil tank , engine has 1850 hrs up, would a set of rings an a hone fix this , back in my 2 stroke days rebored to get everything round , engine is a 914
derekliston Posted August 12, 2023 Posted August 12, 2023 14 minutes ago, rhtrudder said: Noticed a soft compression one one cylinder so ran through a leak down test sat the gauge on 80 , three read 77psi but the sick one was down to 75 psi , I guess not a lot of difference, could hear a faint bubble in the oil tank , engine has 1850 hrs up, would a set of rings an a hone fix this , back in my 2 stroke days rebored to get everything round , engine is a 914 As a retired LAME I would be quite happy with those numbers. Anything above 60 is considered acceptable although on my own engine I’d investigate if it is down to 65! 1
RFguy Posted August 12, 2023 Posted August 12, 2023 (edited) I would think those numbers are within the normal range of the test precision. Sounds fine. If you get low leakdowns , WHY is just as important as the numbers to whether or not it is airworthy. Tank gurgles are normal. For a high hour 914, good numbers- nothing to be concerned about at all. Many rotax go 3000 hours+ without rings being done. Check if the leaks are happening on the exhaust valves- there was a SERVICE BULLETIN for 914 on the exhaust valves (in recent times) . Footnote- For Jabiru- Jabiru engine are not tolerant to brewing troubles like other engines. For Jabiru- Suggest investigating the WHY if leakdowns are lower than 70, and ground the aircraft if lower than 60. A leakdown lower than 60 on a Jabiru engine may indicate imminent engine failure will occur. (valves not closing (and will separate) , stuck/ broken rings, cracked piston) Edited August 12, 2023 by RFguy 1
derekliston Posted August 12, 2023 Posted August 12, 2023 1 minute ago, RFguy said: I would think those numbers are within the normal range of the test precision. Sounds fine. If you get low leakdowns , WHY is just as important as the numbers to whether or not it is airworthy. Tank gurgles are normal. For a high hour 914, good numbers- nothing to be concerned about at all. Many rotax go 3000 hours+ without rings being done. Check if the leaks are happening on the exhaust valves- there was a SERVICE BULLETIN for 914 on the exhaust valves (in recent times) . Footnote- For Jabiru- Jabiru engine are not tolerant to brewing troubles like other engines. For Jabiru- Suggest investigating the WHY if leakdowns are lower than 70, and ground the aircraft if lower than 60. A leakdown lower than 60 on a Jabiru engine may indicate imminent engine failure will occur. (valves not closing (and will separate) , stuck/ broken rings, cracked piston) I fly behind a Jabiru and I agree with you, hence my 65 comment! Good engines, but you have to look after them. 1
