Marty_d Posted August 22, 2023 Posted August 22, 2023 Hey folks, looking for tips and tricks to get the spring clamp on the no. 3 cylinder top coolant elbow. This bastard is under the carb manifold and there's no room for the spring pliers (bent elbow type) to fit. The electrical box thingy is also in the way. I don't really want to disassemble the stuff at the top of the engine to get at this - is there an easier way?? Thanks, Marty
rgmwa Posted August 23, 2023 Posted August 23, 2023 Swearing made it easier. If that fails, maybe try the cable operated pliers. 2 1
facthunter Posted August 23, 2023 Posted August 23, 2023 Hasn't the clamp screw got the option of a screw slot or a small hex spanner? Make you own thin tube spanner with T handle. Nev
facthunter Posted August 23, 2023 Posted August 23, 2023 You CAN use others if access is difficult. That type is OEM on a lot of vehicles. Nev 1
Kev Posted August 23, 2023 Posted August 23, 2023 8 hours ago, Marty_d said: Hey folks, looking for tips and tricks to get the spring clamp on the no. 3 cylinder top coolant elbow. This bastard is under the carb manifold and there's no room for the spring pliers (bent elbow type) to fit. The electrical box thingy is also in the way. I don't really want to disassemble the stuff at the top of the engine to get at this - is there an easier way?? Thanks, Marty Hi Marty. The end caps on the pliers can be swapped over, if that helps (just held on with small circlips) also it may help to turn the spring clamp round the other way, although I assume you have tried that. 1
skippydiesel Posted August 23, 2023 Posted August 23, 2023 (edited) The proper tool can be a bit awkward but a pair of flat blade pliers or even better a modified to suit cheap long nose vice grip, will probably do the job for you. Depending on access/angle - multi grip wrench may also help. Good luck and let us know what your ultimate solution is 🙃. Edited August 23, 2023 by skippydiesel 1
Thruster88 Posted August 23, 2023 Posted August 23, 2023 One way this and other tricky jobs on aircraft can be done is with lock wire. Open the clamp in a vise, lock wire open, slide into position, cut lock wire. Workes on P clamps as well. 3 1 1 2
Blueadventures Posted August 23, 2023 Posted August 23, 2023 16 minutes ago, Thruster88 said: One way this and other tricky jobs on aircraft can be done is with lock wire. Open the clamp in a vise, lock wire open, slide into position, cut lock wire. Workes on P clamps as well. Yep, absolutely agree; works a treat. 2
Marty_d Posted August 23, 2023 Author Posted August 23, 2023 1 hour ago, Thruster88 said: One way this and other tricky jobs on aircraft can be done is with lock wire. Open the clamp in a vise, lock wire open, slide into position, cut lock wire. Workes on P clamps as well. That's a great idea. The pliers actually ratchet closed to lock open the spring, so I'll try that.
Blueadventures Posted August 23, 2023 Posted August 23, 2023 9 hours ago, rgmwa said: Swearing made it easier. If that fails, maybe try the cable operated pliers. This type? not real dear to buy. 1
rgmwa Posted August 23, 2023 Posted August 23, 2023 (edited) Yes, that’s them. Rotax recommend them in their maintenance manual. I almost gave up on that clamp with the standard pliers and was on the point of going to buy a set when I managed to get it installed. Edited August 23, 2023 by rgmwa
Marty_d Posted August 23, 2023 Author Posted August 23, 2023 Well, I think it's going to be Nev' s solution, another type of clamp for that 1 elbow. Not sure why Rotax didn't just extend the elbow so you had clear space to put the hose on, everyone has to do this every 5 years so seems like a design flaw to me. 1
rgmwa Posted August 23, 2023 Posted August 23, 2023 Lock wiring and then slipping it on might be worth trying. I’ve done it on Adel clamps but didn’t think of it when I was doing the hoses.
onetrack Posted August 23, 2023 Posted August 23, 2023 I couldn't recommend any of those Horusdy tools. They brag their tools are "professional" quality. They're the finest low grade Chinese tool quality. I bought a set of their NPT thread taps, and they look like they were knocked up by the rice paddy planters during their Friday afternoon coffee break. 2
facthunter Posted August 23, 2023 Posted August 23, 2023 That can't be right. They don't GET a coffee break any day. Nev 3
Marty_d Posted August 24, 2023 Author Posted August 24, 2023 12 hours ago, rgmwa said: Lock wiring and then slipping it on might be worth trying. I’ve done it on Adel clamps but didn’t think of it when I was doing the hoses. Nope - going to just use a good quality normal hose clamp on that one (bolt style, EFI type if I can get it in that size). Two evenings wasted on it is enough. 2 1 1
danny_galaga Posted August 30, 2023 Posted August 30, 2023 On 23/08/2023 at 10:15 PM, Marty_d said: Well, I think it's going to be Nev' s solution, another type of clamp for that 1 elbow. Not sure why Rotax didn't just extend the elbow so you had clear space to put the hose on, everyone has to do this every 5 years so seems like a design flaw to me. From Rotax point of view it's fine- went together easily enough in the factory, what do they care if it's hard for someone else to remove 😄 1 1 1
