facthunter Posted August 29, 2023 Posted August 29, 2023 I Do think its a relevant comparison. Double declutching is not possible or applicable when one is stopped or running at vastly different revs. If you stopped the other motor you could engage it but that's not available. Nev
Thruster88 Posted August 30, 2023 Posted August 30, 2023 Each engine would most likely drive the gearbox system through a sprag type clutch. Engines can drive but not be driven in the event of failure. 2
Old Koreelah Posted August 30, 2023 Posted August 30, 2023 I believe the Chinook has a similar arrangement. 1
facthunter Posted August 31, 2023 Posted August 31, 2023 It's certainly something else to go wrong. Nev
