RFguy Posted September 2, 2023 Posted September 2, 2023 What factory alternative options are there for rings for 912 engines? Rotax have ONE set of rings for ONE cylinder at $275 !!!! all I can say to the factory is F.O. I am not going to pay that (they want you to buy new engines) I have a 912 with 1900 hours that might want a set of rings. -glen.
facthunter Posted September 3, 2023 Posted September 3, 2023 It's unlikely that Rotax MAKE the original ones. Who makes the pistons probably supplies the rings with them Nev 1
onetrack Posted September 3, 2023 Posted September 3, 2023 (edited) I'm not sure that you'll find satisfactory quality rings a lot cheaper than the Rotax price. The U.S. site below advertises "high quality" aftermarket rings for Rotax, but they're still AU$180, and you'll need to add freight to that figure. The confusing part is they state "complete set" (of rings) - but don't say whether it's a complete full engine set or a complete set of rings for one piston. I did note one site selling individual rings (genuine) for the Rotax 912, which I find rather strange. We used to have a local bloke supplying individual rings for pistons at one time (he's long gone), but he specialised in doing that for people who broke single rings when installing new sets. https://sideslipaviation.com/products/piston-ring-set-for-rotax-912-complete-set Edited September 3, 2023 by onetrack
facthunter Posted September 3, 2023 Posted September 3, 2023 Re-ringing is not very common these days where good air filters are the norm. Often the top ring groove will have some wear if you need rings. For motor vehicles it was Usually the complete set. Japanese motor bikes sell one bearing half for the big ends sometimes.. With the two stroke Rotax's I mostly put new pistons in at the same time. Nev 1 1
onetrack Posted September 3, 2023 Posted September 3, 2023 If rings are worn, the piston ring grooves will be worn too. Manufacturers generally set a specification for maximum wear level on all components. In general, any level of wear that exceeds 50% of the maximum wear specification measurement means that the component should be scrapped and a new component installed. If you want new engine performance, you fit new pistons, new rings and new cylinders. 1
facthunter Posted September 3, 2023 Posted September 3, 2023 The Nikasil cylinders on the Rotax survive well and don't corrode. Some Cont and Lyc cylinders are NITRIDED.. Nev 2
Thruster88 Posted September 3, 2023 Posted September 3, 2023 5 hours ago, RFguy said: What factory alternative options are there for rings for 912 engines? Rotax have ONE set of rings for ONE cylinder at $275 !!!! all I can say to the factory is F.O. I am not going to pay that (they want you to buy new engines) I have a 912 with 1900 hours that might want a set of rings. -glen. Do you know the results of the last leak down? How much beyond tbo are you going? My thoughts, if it isn't broke don't fix it. 1 2
facthunter Posted September 3, 2023 Posted September 3, 2023 You'll feel it when you pull it through when checking the oil level. Nev 1
RFguy Posted September 3, 2023 Author Posted September 3, 2023 Sideslip aviation was a good start. we'll see what else turns up, I will advise if I find further info , thanks for input - glen. 1
facthunter Posted September 3, 2023 Posted September 3, 2023 Glen IF you are going to pull it down I wouldn't order anything until you've assessed it's condition. There's a good argument for replacing high time pistons anyhow it the motor's down in any performance or critical motor. Nev 2
turboplanner Posted September 4, 2023 Posted September 4, 2023 On 03/09/2023 at 9:56 AM, RFguy said: What factory alternative options are there for rings for 912 engines? Rotax have ONE set of rings for ONE cylinder at $275 !!!! all I can say to the factory is F.O. I am not going to pay that (they want you to buy new engines) I have a 912 with 1900 hours that might want a set of rings. -glen. It does come as a shock but when you realise that these engines rely on exotic processes and specifications that produce power beyond the dreams of the old 1960 equipment where a set of rings was petty cash it makes sense. Don’t forget this engine family comes from JetSki and Snowmobile applications where bhp over 300 is not unusual. In this market if you want to operate economically you always sell the product before the unscheduled maintenance is due to start. 1 1
BrendAn Posted September 6, 2023 Posted September 6, 2023 On 03/09/2023 at 4:43 PM, facthunter said: Glen IF you are going to pull it down I wouldn't order anything until you've assessed it's condition. There's a good argument for replacing high time pistons anyhow it the motor's down in any performance or critical motor. Nev 1900 is not bad for a 912. i know of a 100 hp 912 that has 3600 hrs and is still passing leakdown tests. doesn't burn oil either 2 1
facthunter Posted September 6, 2023 Posted September 6, 2023 Pistons fatigue. It's not just about wear. and they are in an aeroplane. Buying the piston(s) compete with the matching ring set is cheaper than with those parts separate. Often done with 2 strokes for the same reason. Nev 2
facthunter Posted September 7, 2023 Posted September 7, 2023 BTW I've done more research on the Later 9xx engines . As well as a stronger case the crankshaft has been made stronger. It's all on a rotax website about the company. Nev 1
facthunter Posted September 7, 2023 Posted September 7, 2023 IF the crank is out of true there's no fix permitted even by the factory. You get a new one. It's not made to be pulled apart and reassembled as you can't keep the tolerances needed. Nev
