For anyone interested, I have found a new perfect replacement for the display for this autopilot .
Backlight function is OK . Display contrast is good and is a transreflective display so it  can work in full sun.
Fits just fine, just reverse the standoffs  (order = SCREW > washer > plastic standoff > PCB ) and put the display against the panel.
chop/ disconnect pin 1 on the connection (backlight aux ctl)
Display is a NMTG-S12232CFYHSGY-10  by Microtips, AVBL from Mouser.
You'll need either magnification or a microscope to change the LCD over since the flex cable is 1.27mm and quite tight on spacing.
