The aircraft looks very unstable, maybe that was the wind. I could see the direction finder but not the distance to you in the HUD, where was that?
RC aircraft have a much greater power to weight ratio than the real thing so things happen a lot faster.
This is a first flight so there may be bell crank changes, but also some pilots are better than others at modulation, and some are not trying to imitate real flight appearances.
Bad cross wind on that day and we get turbulence off the top of the trees at that location. I was focussing on reading the telemetry more than smooth flying most of the time. Some improvements still to make. Not sure why distance to home wasn't showing in the telemetry. I will look into that. And because I'm using a flight controller I will on future flights take advantage of the gyro stabilisation.
Thanks, since flying Ultralights I don't have time to fly RC anymore which is a pitty because I loved it. I love watching your videos.
A lot of leading edge sweepback has to make control touchy and need gyro  stabilisation anyhow.  Nev
