red750 Posted January 22, 2024 Posted January 22, 2024 A Sydney Airport worker drove his vehicle into the engine of a parked Jetstar aircraft. They're so small they are easy to miss, although in this instance, he didn't miss. Â
red750 Posted January 22, 2024 Author Posted January 22, 2024 Sorry. Later news report says the aircraft was being towed. 1
Roundsounds Posted January 22, 2024 Posted January 22, 2024 Obviously the A-320 had the ADSB turned off. The driver of the ute had no chance 4 1
facthunter Posted January 22, 2024 Posted January 22, 2024 Bugger! This ute is supposed to be unbreakable?  Nev 1 1
Jabiru7252 Posted January 23, 2024 Posted January 23, 2024 Probably a moron driving the car, becoming common these days.
facthunter Posted January 23, 2024 Posted January 23, 2024 (edited) Do you mean the UTE ? It was parked wasn't it. Anyhow I think there's clearance lines marked out and I wouldn't think you'd leave a vehicle inside them . The plane should be keeping an eye out also .. Expensive and shouldn't happen. Nev Edited January 23, 2024 by facthunter
spacesailor Posted January 23, 2024 Posted January 23, 2024 Did that plane , get towed into the stationary Ute. spacesailor Â
Methusala Posted January 23, 2024 Posted January 23, 2024 Perhaps Joyce should have kept the experienced ground staff!
Thruster88 Posted January 23, 2024 Posted January 23, 2024 These are Sydney airports corporation contractors.
planedriver Posted January 23, 2024 Posted January 23, 2024 Pass me the situations vacant section someone. 1
facthunter Posted January 23, 2024 Posted January 23, 2024 Was it being towed? That is not very common. Mostly it's just push back to a position clear of the finger and disconnect the tug.  Nev 1
skippydiesel Posted January 23, 2024 Posted January 23, 2024 When I drive past Sydney Airport (Mascot) I see plenty of parked aircraft, well away from the terminal buildings. 1
facthunter Posted January 23, 2024 Posted January 23, 2024 The ones coming and going are the biggest % of apron movements. Was the plane under it's own power? Nev
