Curious.
"Down here" which way would birds be flying if they are in a thermal?
CW or CCW?
High-pressure spins CCW down here.
So the birds would be going CW - yes?
I have never noticed any one direction, I would think they would circle into the highest lift either direction like a glider.
I think cw is right.
Everyday I watch birds here at Port Stephens soaring at low levels and it's almost always cw from ground level to at least 500feet.
Masses of sea birds esp Sea Eagles and pelicans to watch.
Plus plenty of others that will soar if any currents are around.
I watched a pelican soaring over the house this morning in thermals at about 500 feet (a quite unusual sight, I might add, I've never seen one here before, I'm quite a few kms from open water) - and he was going CW.
 The airmass would be rising whichever direction you flew in it as long as you stay within it's confines. but your groundspeed would vary. Into wind would allow a tighter radius and that's an advantage.. You can feel the edge of the thermal tugging your wingtip down.  Nev
Facthunter,
That is an interesting point.
Though the others are also interesting.
(To the first ones)
Yeah, ok, the direction of their "spin" would depend if they wanted a high or low airspeed.
Which maybe isn't of importance.
It was just something that got into my head and I asked.
Thanks all.
Thermals are generally a quite small diameter. Better to go slow(er) (into wind) than the opposite to keep the bank angle lower and have less drag and stall issues.  Nev.
I havent seen too many bird's stalling lately !    Just taking the pi$$ and being stupid
  • Haha 2
Good point, they probably fly correct airspeed or angle of attack, which ever is their preferred method.
Birds takeoff into wind - possible exceptions are those that , when startled, "explode" into flight from cover eg chickens, pheasant and other low scrub dwelling birds.
My guess they will "thermal" to their best advantage, probably into wind
They go into wind same as best for gliding is into the direction opposite turn when possible.  Birds are smart and efficient watch their V pattern flight.  Years ago I tricked an eagle by when in sink and seeing it coming over I turned sharply as if centering a thermal and I was in sinking air.  The eagle quickly joined with me and set itself to thermal and immediately started flapping its wings as if it got bogged and was in 4 wheel low getting back up to flying speed.  I still smile thinking of that day.
  • Like 3
  • Haha 3
We have a pair of Magpies here with a young baby.
The parent's when coming into land on a windy day turn into wind just as the let down...baby has yet to master this maneuver...comical..
Bernie.
Was just watching a couple of Wedge-tails, both circling anti clockwise. I'm gong to be highly controversial here and say maybe most thermals and not all air movement rotates? A thermal is a bubble of air moving up, why is it rotating?
They rotate because any movement of a gas or liquid not restrained, is subject to the Coriolis effect. However, the Coriolis effect is minimal when gas or liquid speeds are slow, or the travel distance is short.
It doesn't long though, for heated rising air to start to spin. Ever seen a willy-willy/cock-eyed bob/mini-tornado, crank up? They will start to spin only 15 to 20 metres above hot ground.
https://education.nationalgeographic.org/resource/coriolis-effect/
Interesting fact: A friend who was an artilleryman during the Vietnam War told me how they had to calculate the Coriolis effect on the target point of 105mm artillery shells that were fired at long distance targets.
Even more interesting was the fact that these calculations were done manually, longhand. No hand-held calculators back then.
  • Informative 2
We had a neighbors young chook in our garden a few weeks back.
As I approched, it took flight following the path between the trees but wound up slamming into the fence at the end.
I think it should have read Nevs post about gaining altitude by taking off into the wind.
  • Haha 2
,Contrast the Cockatoos landing on the long rubbery branches at the top of a pine tree, waving in the breeze.   Nev
I have never seen a chicken in a thermal, regardless of direction.  What have i missed out on ?
I do know they turn clockwise at my local chicken shop, even with a skewr in both ends.   🤣
  • Haha 4
That was me, just having learned to hang glide at 23.
  • Haha 2
Posted (edited)
I've seen a chicken in a thermal....
Oh, wait, sorry:  It was an oven!
And it was turning CCW.   😉
Sorry, now off topic:
This is how birds go  BOOM!
Onetrack:
WRT "the old ways" I once found/saw a thing on youtube about old analogue computers and gun sights.
On a battle ship firing a gun.
How they calculate angle from wind speed, ship's speed, direction and all that stuff.
All done with MECHANICAL gears.
'twas amazing.
Sorry I can't give a link.
Ok, maybe this one.
After a bit more digging, I think this was the one I saw:
Edited by flying dog
Mechical computers , named ,
sliderules , were used in WW1 .
1925 " Loga- calculator- sliderule .
My cylinder sliderule , is modern ,1950s .
It works the same as standard sliderule , with a Long long length .
spacesailor
