facthunter Posted March 12, 2024 Posted March 12, 2024 A bromine based additive was used to scour lead from the combustion chambers and that went out the exhaust. How would any oil additive remove lead from the oil? It might keep it in suspension so it goes out when drained but that would require an explanation of the effects on the oil and the chemistry involved and a warning about disposal if such oil. There's also a lot of different SYNTHETIC oils Ester based ones are still around. . This is for the experts not the internet surfers. Nev
skippydiesel Posted March 12, 2024 Author Posted March 12, 2024 On 12/03/2024 at 3:06 AM, facthunter said: A bromine based additive was used to scour lead from the combustion chambers and that went out the exhaust. How would any oil additive remove lead from the oil? It might keep it in suspension so it goes out when drained but that would require an explanation of the effects on the oil and the chemistry involved and a warning about disposal if such oil. There's also a lot of different SYNTHETIC oils Ester based ones are still around. . This is for the experts not the internet surfers. Nev Expand You exceed your knowledge base
Red Posted May 27, 2024 Posted May 27, 2024 I've always used any semi synthetic motorcycle oil that was up to spec (most exceed spec) and happened to be available, I dont put much store in the various claims of superiority the competing companies make they all have to pass the same tests for quality and performance Just my opinion, I have others😁 2
facthunter Posted May 27, 2024 Posted May 27, 2024 Oils are getting more application specific all the time. You can risk a serious failure if you don't use the product meeting the Maker's specification. Nev
spacesailor Posted May 28, 2024 Posted May 28, 2024 I'm told to use " none " synthetic oil in my " old " style half Volkswagen motor . ( 30 w ) But I like the new oil that ' thicken's ' as it heats up . ( there's a name for that ) .. 20/50 w, runs like 20 when cold but is like a 50 w when hot . spacesailor
facthunter Posted May 28, 2024 Posted May 28, 2024 Same oil with additives and a shorter life. for multigrade. Nev
Red Posted May 28, 2024 Posted May 28, 2024 On 27/05/2024 at 11:42 PM, facthunter said: Oils are getting more application specific all the time. You can risk a serious failure if you don't use the product meeting the Maker's specification. Nev Expand The oils I use meet or exceed the makers spec, which of course is not the same as "recommended" which is far looser term often influenced by factors quite apart from efficacy
spacesailor Posted May 28, 2024 Posted May 28, 2024 I'm told " synthetic " is ' Less ' sticky than 30w grade. As I give my motor lots of turns to raise the oil pressure It should be good to go with lots of oil already circulating In the cold motor . spacesailor
facthunter Posted May 29, 2024 Posted May 29, 2024 You can get TOLD lots of things. Todays synthetics mix with ordinary oils but are of more consistent quality. Most are made from " LNG." Nev
BrendAn Posted May 29, 2024 Posted May 29, 2024 On 28/05/2024 at 1:00 PM, spacesailor said: I'm told " synthetic " is ' Less ' sticky than 30w grade. As I give my motor lots of turns to raise the oil pressure It should be good to go with lots of oil already circulating In the cold motor . spacesailor Expand i always wind my jab motor over with mags off until oil pressure needle moves. i don't know if it really makes any difference though. 1
facthunter Posted May 30, 2024 Posted May 30, 2024 Can't do any harm. A rebuilt motor, I always prime. Nev 1
