Hi
Does anyone know who could supply the tap or hardware/plumbing to switch between dual fuel tanks? This is for use in a car so would be switching fuel input and fuel return (EFI setup). Thanks in anticipation.
Have a look at Wicks or Aviation Spruce to see what you need and if you see what you want, either buy it from them in USA or try Aviaquip. [email protected]. They seem to carry a pretty good range of gear.
Be aware that aviation flared joints are 37 deg, not the same as auto flares.
