Red Posted June 13, 2024 Posted June 13, 2024 Bttery is fine?, check the acid/water level, dunno how long you've run it that voltage but it would have been gassing
Damien Posted June 13, 2024 Author Posted June 13, 2024 1 minute ago, facthunter said: I only have a PC. If I'm away I'm essentially out of contact on line. Sometimes Microsoft mucks things up for a while also. For ME life used to be a BEACH. Nev 🫡
Thruster88 Posted June 13, 2024 Posted June 13, 2024 4 hours ago, BrendAn said: might be why he needs a new tacho The tacho on a 582 works from a single independent coil on the stator. Two wires from that coil go to the tach, no 12 volts involved. 5 hours ago, Damien said: The clear square type I think the original That type supplied with the 582 requires a minimum load of 1 amp to regulate correctly. The voltage will go high with no load. 1
Damien Posted June 13, 2024 Author Posted June 13, 2024 1 hour ago, Thruster88 said: The tacho on a 582 works from a single independent coil on the stator. Two wires from that coil go to the tach, no 12 volts involved. That type supplied with the 582 requires a minimum load of 1 amp to regulate correctly. The voltage will go high with no load. That’s why I’m suspicious of the regulator because the current was 7 amps to the battery so in essence more than 1 amp and I think the tacho has just had its day maybe and thanks to Brendan for his advice and offering of a spare one I do appreciate it a whole lot .
Blueadventures Posted June 13, 2024 Posted June 13, 2024 (edited) Voltage above 15 or 16 volts can damage / destroy internal components of 12 volt instruments, radios etc as a general rule. I've seen over voltage (16V DC as an example) destroy a boats depth sounder (screen went black across and voltage display showed 16.8 volts at the time) and took out the VHF marine GME radio. Edited June 13, 2024 by Blueadventures 1
danny_galaga Posted June 15, 2024 Posted June 15, 2024 Check https://www.vectriqparts.com.au/ They do better than original replacement regulators etc for lots of bikes and at least the Rotax 912, which I have. I couldn't immediately see if they have your one but worth a shot.
Damien Posted June 16, 2024 Author Posted June 16, 2024 18 hours ago, danny_galaga said: Check https://www.vectriqparts.com.au/ They do better than original replacement regulators etc for lots of bikes and at least the Rotax 912, which I have. I couldn't immediately see if they have your one but worth a shot. Thankyou
