20 year old killed in 2 seat aircraft on a property near Lake Cargelligo NSW this morning.
An all too common way of ruining your day when spraying. Usually later in the day when you're tired. NOT saying that is the case here. Nev
A mate, "Contemporary" of mine started spraying cotton at night in a CERES. Hit a patch of warm(er) air and cartwheeled into the crop.  Nev
  • Sad 1
A lot of students go through training in calm air without getting a serious rotor, shear, crosswind gust and destroy the aircraft while they are doing a beat up.
In this case there aren't too many cluse but we will get an ATSB analysis.
Power lines will get you every time, even when you know they're there, just a few seconds distraction is all it takes. Crop dusters die at probably triple the rate of other types of pilots.
  The Bulk of their flying is at critical weights heights and speeds. Towards the end of the day is the most likely time to forget a wire. Nev
Posted (edited)
And I've see from the farmer side at the end of the work. "If you've still got spray in the tank could you do the home paddock?" and that late in the day.
Edited by turboplanner
