23 hours ago, BrendAn said:
he was flying 100 ft below minimum legal height so when things went bad they were on the ground in an instant.
i went past there tonight on my way to work, there would have been close to a dozen people walking around the site.
very thorough.
the thing i keep thinking about is the parents who lost 2 sons and a nephew at once for no good reason.
Below minimum legal height? 100ft too low?  Are you using altitude from FR24, adjusted for QNH?  Had they been flying along too low? Or descended due to an onboard issue? I've no idea. Just bloody sad at the loss of 3 lives. Can't even imagine what the families and friends are going through. Hope they are well supported.
Losing one life is bad enough but losing three is a tragedy under any circumstances. That’s one reason I generally prefer to fly alone, especially if the passenger is a trusting non-pilot who is relying on your skill and your aircraft to get them home safely.
Off fr24 .  I don't know how accurate it is. I would have thought it would be close.  I am only guessing the same as everyone else. I still think it will turn out to be a stall spin .  They had completed a couple of circuits around the farm before the accident .
You are right it is a terrible tragedy and it's only 15 km from my house.
The thought of losing so many family members at once is hard to contemplate. Rip.
It's awful.  But please be careful saying they were flying below legal minimums.  FR24 isn't adjusted for QNH and that could easily make the difference.  Family & friends could easily be impacted by statements like this.
It's already on the net before I said anything. Ask f10 what the qnh was at the time. He flew just before them. Tinamba area is dead flat irrigation farms  between 100 and 200 ft above sea level. It was around 28 deg
Edited by BrendAn
8 hours ago, facthunter said:
 "Pilot Error" is an expression that has NOT been used by  investigators for quite a while. It actually gets you nowhere. There's ALWAYs some reason, why? Investigation is justified as being a way of improving safety Not just apportioning blame. A convenient answer as there's always a pilot at the scene of the crash. Yes Pilots are human and to err is human. . We must reduce the Frequency of these so called human error crashes. HOW is the hard part. Zero accidents is not possible but to not try to reduce them is dereliction of responsibility.. No one goes flying expecting to end up dead. That's obvious. We also think it only happens to others. Safety has to be an ethic. IF you're not sure check it again. Look again. don't show off. Don't be distracted. Fly to the conditions and your and the Planes Limits.. I'd hate to injure anyone or have a student prang because of something he wasn't taught  in a situation I've supervised or been a party to. Set a good example to others. Everyone has a part in it.  Nev
I can't agree with this more.. Often the cited reasons, eg. another flight into IMC by an unqualified pilot probably tells of the symptoms, but not the problems. I had read many ATSB, AAIB, NTSB, and other governments' investigation units reports, and they all mention pressonitis, but but not how it can afflict you. Of course, while reading the stories, I was thinking I would never succumb to it.
I found it afflicted me - twice. If I had of let the second event go a minute or two longer, I many not well be here to talk about it. On reflection, there were exceptional circumstances in both situations, and I was under a lot of pressure at the time. Self-reflection after the second one was a cosnscious effort to develop techniques to identify it and steer clear away from aeroplanes.
One of the hard things for investigators to do is get teh reasoniong of a particular case when the pilot and passengers are dead. Over here, we have CHIRP:
I have submitted my two reports with reflections that hoepfully I and others will learn from. I know the ATSB  has a self-reporting scheme but I am not sure the reports are called out in the same way.
Well yes, however over 800 hours on Harvards in the military and countless stalls powering/off, g-stalls, incipient and full spin recoveries plus extensive aerobatics, and in a Skyfox Gazelle @ a MAUW of 520Kg’s, made me comfortable at 2000Ft agl. But yes, always stick to your comfort zone.
  • Winner 2
 You fly at low level on take-off ,landing and go arounds. We all need competence  in this Phase of flight. I always say you don't really know exactly WHAT happened in most cases.. We don't want it to happen . . It's unlikely the plane was overloaded.  There are many variables possible.  I've had Gazelles that we trained in when you would take ages to get to 4,000 ft. on warm days with "larger" people on board.  I had a 6 cyl Continental  have one hydraulic lifter fail and it wouldn't climb at 400 ft. Luckily it came good saving me from settling into a field of large tree stumps that would have ruined my day for sure. Nev
22 hours ago, Flightrite said:
I sure as hell wouldn’t be doing unbalanced stalls etc at 2000 ft!
Thought this post was after the quoted one, but no, so this re-posting it.
Well hell yes, however over 800 hours on Harvards in the military and countless stalls powering/off, g-stalls, incipient and full spin recoveries plus extensive aerobatics, and in a Skyfox Gazelle @ a MAUW of 520Kg’s, made me comfortable at 2000Ft agl. But yes, always stick to your comfort zone.
Graveyards are full of ‘expert’ aerobatic pilots!
True, but the track and heights of this VH registered aircraft don't indicate aerobatics, but the common killer; sighteeing and/or getting photos of homesteads.
The aircraft is flown low - 500 feet agl is a good height for a standard camera lense.....and also the minimum legal flight level, and most people about to take photos are not focused on a suitable height for a stall.
The pilot starts out with a shallow enough turn but the person with the camera is shouting "CLOSER!" "CLOSER!!!" "Stay there!, I've just about got it!" and the pilot gets tighter and tighter until the aircraft lets go.
I'm not saying this is what's happened here and with ATSB investigating, their decision will be based on a lot more actual evidence, but I don't see any evidence here of beat ups straight over the houses or aerobatic displays, just multiple turns above the properties which I've done lots of times. It's normal to rev the engine or give some other pre-arranged signal, because people on the land are prone to saying afterwards that they didn't see you, and "Oh yeah a plane went over the house about that time."
If you want to avoid a similar accident to this, don't do the circling bit, come straight in towards the property, offset so the person with the camera can get a good shot, climb out. That was you have a clean, stable 500 - 600' camera pass and your turns are similar to circuit turns. Passenger needs a shot from another angle? From your shallow turn at higher altitude drop down to camera height and fly another straight line towards the new view requested.
Another way to avoid this is what I do - hire an Instructor and do a 15 minute brief before the flight: the Instructor is in the LH Seat, he/she is PIC at all times and responsible for height, other traffic etc. I point to where I want to shoot once we descend to photo level, and it's optional for the PIC to abort. We then just fly on and come come round in a cloverleaf for a second attempt. In a pre-planned 1 hour flight I get roughly 40 good shots, a few fuzzy ones, and about three go rounds resulting in good shots. We haven't spoken over the photo area and when we land the Instructor is happy and I'm happy.
8 minutes ago, red750 said:
. They were circling Daly's farm where the youngest one lived. They were not flying to Maffra because there is no airfield at Maffra. Daly's are a well known local family.
Yes true, aerobatics below 500Ft its no mans land, no matter how good you are. But if you are calling stalling exercises aerobatics, think again.
It has probably been said before but young and experienced and a flight instructor means he was a pretty good pilot. The missing link is time and that hopefully provides wisdom. If it was a stall turn at low altitude then getting caught up in all the fun of it with mates that young can very easily lead to a loss of situational awareness and over confidence.
Edited by kgwilson
I've never seen too many young men who didn't think they were invincible - especially when it came to driving something with an engine in it.
  • Agree 5
Anyone who witnessed the incident, with footage, or information is urged to contact Crime Stoppers.
This is the last line of the media report. Is that usual or is there something they are not telling us?
With ATSB on the scene that comment probably wasn't necessary, but with police at the scene first they may have declared a "crime scene" which doesn't imply that a crime has been committed, just preserves the scene better and more formally, and that may have triggered the Crime Stoppers requesyt which is the formal way police ask for information from public witnesses and filter it to free up police time. Witness calls to Crime Stoppers would flow to ATSB when they get involved just like evidence from first responders.
Police are eternally suspicious and any event involving major loss, major injuries and deaths will often be considered a potential crime scene and placed under restrictions for evidence gathering, until it can be proven that no suspicious circumstances exist or evidence-gathering is complete.
If you have a house fire, even one which is obviously accidental, expect interrogation by the police as part of the trauma and investigation.
On 16/11/2024 at 8:52 PM, BrendAn said:
SPECIFICATIONS:
  • Wingspan: 7.92 m (26 ft)
  • Length: 6.70 m (22 ft)
  • Height (tricycle undercarriage): 2 m (6 ft 6 in)
  • Wing area: 10.26 m² (110.5 sq ft)
  • Cruising speed at sea level: 241 km/h (150 mph)
  • Manoeuvring speed: 167 km/h (106 mph)
  • Stalling speed, clean: 56 km/h (35 mph)
  • Stalling speed, with flaps: 50 km/h (31 mph)
  • Service ceiling: 3,048 m (10,000 ft)
  • Rate of climb at sea level: 366 m/min (1,200 ft/min)
  • Empty weight: 353 kg (778 lb)
  • Loaded weight: 800 kg (1,764 lb.
it has quite a low stall speed and 50knt approach.
Rule of thumb for a decent approach speed: Stall 35mph * 1.3 = 45.5mph vref + 50% steady state wind value + 50% gust value,
So on an example 10G15kn day approach would be 45.5mph + [5kn]5.75mph + [2.5kn]2.9mph = 54.15mph or 47.05kn - so 50kn seems ok on an average day....
Anyhow to the only people who really know what happened rest in peace, and my thoughts for those poor loved ones left behind in this tragedy [as always].
Yes! In addition, what is the effect of load factor? In a level 60 deg AoB steep turn, you need to hold 2g. To see the load factor effect, take the square root of your 2g load factor (1.4) and multiply 50 Kts Vref by 1.4, that gives you 70 Kts!! So wanging around in tight orbits…better bump up the safety speed! This is an exponential effect. A 4g turn will double your aircraft’s stall speed.
Totally agree. The question was about approach speed only, and my old rule of thumb works well. However nothing wrong with adding another 10-20% on [as long as you aren't getting near structural limits like Vfe and runway length isn't a problem]. For the avoidance of doubt ANY turns on the glideslope should be gentle, coordinated ones and you are 100% right to bring this up.
Good information. I learnt the hard way trying to do a 90 deg turn in a Chipmunk.
If the instructor hadn't been on board I would have drilled it into the ground, having no idea of what was happening. Haven't spent the need to demonstrate the 90 deg turn like my uncle demonstrated to me.
4 hours ago, facthunter said:
AND the Husband of any murdered woman is the initial Prime suspect. Nev
It's a sad reflection on society that too often it turns out to be true.
