My Biennial Flight Review (RAAus Pilot) is approaching.  When I checked two years ago with RAAus, the cross-country endorsement is not actually a separate BFR retest requirement... however, the flight instructor I chose last time decided to make it so.   So I ended up navigating without GPS for a few hours just to demonstrate I could still do it.
Whilst it's probably a good relearning exercise, I have 2 separate GPS on the panel and two further (Ipad, Iphone) in the aircraft, so perhaps the E6B/map/watch approach was not the best use of either my time or my money.
Two questions to the forum
a.  Have you been required to do cross-country navs on a BFR?
b.  Can you recommend a good RAAus CFI in the Melbourne area who is "pragmatic"?
I have the same issue with a PPL BFR.  I have not flown without a gps since 2000.  My flight calculator that I used in the 1980/1990s is lost.  I bought a circular calculator, I am 77 and it is a chore to learn.  I even said that I only want to fly locally with friends and family.   No they are demanding a flight navigation without GPS.  I ha e now walked away from them, anyone know a Flight School near Sydney that have a reasonable attitude, as per the CASA recommendations?  Was i just being overstrained?  Maybe.
You should still plot a route on a WAC chart and be able to derive track angles, distances and LSALT's and know magnetic deviation and drift angles and 1: 60 applications. It's NEVER good policy to trust one only basis for going somewhere. That's what happened with the Mt Erebus disaster. Your "prayer wheel" is mainly a circular slide rule but very good at deriving cross winds from drift and G/S figures fuel consumption etc. . . Nev
Mt Erebus, was a government oversight.
they forgot to inform the pilot's , of the new navigation correction.
Then ,  tried to put that disaster onto the pilot . " pilot Error " .
spacesailor
Had they backed the flight path up with some other basis it would not have happened.  Even a track plotted with the known winds.The first thing they knew was the GPWS going off at about FL 160. Yes the  CHANGED track should have been better informed.. They had no horizon and no viz It was a white out and the  Mountain was where it always was. . Yes the MANAGEMENT did try to blame the Crew. Their testimony was referred to as a "Littany of Lies" Nev
I have never been asked to do a cross country for a BFR in NZ or Australia. Seems to me they were trying to extract the maximum amount of flying/beer vouchers out of you. If they want you to show competency in x country then there are many ways to do this on the ground.
Why???  I just want to fly around the patch, BFR is not intended to be an exam, more a review of what flying you do.  When I was flying long distances across Australis and outback flying I use EFIS and GPSS 3 off in the aircraft etc), now I just want to fly around the patch.  I know that the wheel is just a slide rule, I have 3 yr level university level in mathematics, I know nav and would revise it if I ever wanted to fly away from the patch.  I am so knowledgeable about mathematics to know that the 1:60 rule should be a 1:57.3.
 You can go 25 miles without a nav endorsement. . 1:60 is only a rule of thumb so there's no need to be precise.  What I think doesn't matter anyhow. Check with those who make the rules.. Nev
I do flight reviews for some people, however not in the Sydney area. The new regulation is very onerous if you bother to read it, 61.400.
Fortunately, sensible people within CASA have stuck to the original CAAP 5.81-01 which references the obsolete regulations. Many flight schools use the forms provided there as a record of flight reviews given which are subject to CASA audit. Refer B1 on page 31 and you will see that Navigation is recommended. There is some text as guidance BUT ...
CASA also has their Plain English Guide for Part 61 which reflects the regs so contrary to the CAAP.
"You must demonstrate competency according to each unit of competency mentioned in the MOS (Schedule 2)." Read those words and navigation is not recommended, it is mandatory unless one just holds an RPL without a nav endorsement.
"The purpose of a flight review and a proficiency check is to assess your flying skills and operational knowledge."
(Sounds like a test to me.)
Gone is that sensible bit in the CAAP: "To properly inform the task of designing the flight review, the pilot under review should
accurately detail what flying they have completed over the last two years, and what flying they anticipate they will undertake in the future."
Do I follow the old, but still current, CAAP or the CASA guide explaining the existing regulations?
The wizz wheel (computer) for pilots is like trigonometry tables for high school & uni students, know that they exist & can be found in a museum, the world has moved on.
  • Agree 4
When I suggested that I do gps navigation, 500 hrs experience with gps navigation, I was told that I might encounter RAIM.  I thought that RAIM only applies to IFR. I carry 3 GPS, Farming 196, small pocket GPS and phone, could all 3 go flat once?
From memory about 3 people on this site over the years reported that 2 had failed and they'd winged it to get home.
In many cases, such as eastern Victoria, it wouldn't make much difference.
In other cases the lead you need for the second GPS you've never had to use could be at home.
Even that wouldn't be a problem most of the time because you would have a pretty good idea of where the key towns were.
But one guy who used to boast about modern equipment on this site got lost ....in a helicopter.
I carry batteries for Garmin and pocket and hand held radio.  I carry extra ELB, polished stainless steel, water and even maps.  And yes while I try to eliminate single mode of failure as a retired engineer believe me that single modes of failure will always find a way to be found at the worst possible time.  .Murphy was an optomist.
You CAN use tso'd GPS just as you use any instrument. You can do a PIFR rating. . VFR is another matter. Continuous reference to the ground or water. Get fixes at frequent intervals.( Positive identification of  some feature) The way I see it that's part of the deal.  Includes looking out for conflicting traffic and being able to describe where you are . The majority of my flying is on instruments Over FL210 is IFR. You have to hold a current rating on your licence to do that and operate a plane with approved systems. and keep a track accurately etc.   Nev
Maybe the name BFR should be changed to BFT (Biannual Flight Test) or BFE Biannual Flight Exam).
It hasn't been called BFR for many years.
CASA's Plain English Guide describes flight reviews on the same page as proficiency checks.
When I do a PC to renew my instructor rating it is definitely a test.
"Like a flight review, a proficiency check assesses your competency to the standards specified by CASA."
Perhaps you should look for a grumpy old flight instructor who simply follows the CASA CAAP with no regard for the current regs.
(To note that the Part 61 regs do not apply to RAA.)
I don't think there's much to be had from debating whether it's a flight-Test or not.. IF you don't complete it satisfactorily, then you don't fly until corrective action has been taken. Nev
I’m of the firm belief that it’s too easy to get a plane ticket at the lower end of the spectrum and too easy to keep it! The amount of Pvt pilots I’ve gone along with for ride that are very slack in all aspects of their flying is astonishing! I partly blame the testing officers for this,they let too many slip thru the cracks of their AFR’s and it shows!
Pilots should be striving to improve, doing it better rather than finding short cuts and the cheapest quickest way around an AFR!
It doesn't matter what the rule book/CASA calls it, everyone that I know refers to it as a "BFR"
Its amazing how Gov bodies regularly go through a costly time consuming change of name/terminology. Presumably to give the illusion of progress. The public (us) continue to use the old, that is until a new generation comes along , "edjimikated" in the new way. The new way will be supplanted in due course.😈
