Hi All,
I need to replace a hot air duct. The critical dimensions are ID & length.
ID 61.6 mm x Length 550 mm
Fitting over existing structures/supports is the reason for the ID (could probably get away with a little bigger, but smaller would be problematic). Original tube had an aproximately 1 mm wall thickness.
I think OD is going to be around 2.5 in, in the Devil's measurement system that most suppliers seem to use.
Note: measuring device (& operator) not as precise as might be hoped.
Have tried all the aircraft suppliers of tube, that come up on Google - no joy.
Tried a few commercial aluminium suppliers - min wall thickness 2 -3 mm in this size pipe, making ID way to small .
Currently corresponding with a custom intercooler builder but not holding out much hope.
Suggestions welcome
  On 02/12/2024 at 4:16 AM, skippydiesel said:
Hi All,
Suggestions welcome
Laminate an FRP tube; make 2 halves bolted together.
  On 02/12/2024 at 4:54 AM, Thruster88 said:
Why not scat hose as used in aircraft?
Thanks Thruster,
This is an part of an exhaust extractor system. Dont think SCAT would tolerate the heat for very long.
Thanks Turbo,
The original pipe (that I damaged) is metal - I think aluminium alloy but may be something else.  Came with the partially completed project, so I assume sourced in AU.
I did toy with the idea of ' aluminium tube " instead of rubber hose ( oil-cooling ) to the oil filter , as a weight saver,  plus heat extraction .
Put into the " too hard basket " .
spacesailor
So this sounds like an exhaust augmented cooling system? One option would be to roll the desired material  and secure with hose clamps or tig weld.
  On 02/12/2024 at 8:44 AM, rodgerc said:
Thanks Roger - Most of this pipe has the wrong ID but as I said I am talking to a custom intercooler manufacturer who may be able to assist me.
Good thought Thruster.  Tig weld would be the way to go. Any suggestions as to who might provide such a service?
I know a good tig welder however I would favor the hose clamps because this will allow the aluminium to grip the underlying steel? support structure. Many certified aircraft cabin heat muffs on the exhaust are done this way, PA28 etc. Just allow some over lap at the join.
The duct (part of an exhaust extraction system) need to be reasonably air tight or wont work. Overlap might do the trick, clamps add significantly to weight but a lot cheaper than welder time.
Seems that 61.6 ID rolling is considered to be more of a hobby than a commercial service.
I can purchase a 610mm "slip roller" for $473. Tad expensive for a one off. Anyone out there got one I can borrow/use/pay you to do the job.
  On 02/12/2024 at 8:38 AM, onetrack said:
Skippy, here you go, from our finest quality aircraft parts supplier...... 😄
https://www.aliexpress.com/i/33009213721.html
Being the Xmas month, and the fact AliExpress sellers use any old fly by night couriers at the receiver end, you should get it by early February if you order now 😄
Tempting Danny.
Will hold out a little longer in the hope of finding  a "stiff" pipe.
Thanks
